Loud ticking noise when starting engine after cold night? - Benzworld.org - Mercedes-Benz Discussion Forum
» Auto Insurance
» Featured Product
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Roadster Forums > R171 SLK Class
Old 12-27-2008, 08:13 AM   #1 (permalink)
aquascape's Avatar
Date registered: Nov 2004
Vehicle: Mercedes SL350 2009
I get a loud ticking noise for about 30 seconds when I start the car after it has sat overnight on a cold night (sub zero).
Lasts about 30 seconds, doesn't get louder when you rev the engine but does get louder when you drive the car.
Just suddenly stops after about 30 seconds to 1 minute of driving.
Anyone have any ideas?
SL350 SPORT 2009
OLD CARS
SLK55 AMG, SLK 350 , SLK 230K, MR2, Mitsubishi GTO 3000
aquascape is offline   Reply With Quote
Old 12-28-2008, 01:21 AM   #2 (permalink)
Date registered: Jan 2007
Vehicle: 2005 C230K Sport Coupe 6-speed!
The most likely cause is lash adjuster noise. As the engine sits overnight, the oil drains back to the oilpan. Of course, first thing in the morning with the oil being thicker, it takes a little while for the lash adjusters to pump up with oil. It is normal on many cars, including my C240. The only time you should be concerned about it is if it doesn't go away. If it doesn't go away, the most likely cause is low oil level or bad adjusters.
Whosdis is offline   Reply With Quote
Old 12-28-2008, 01:15 PM   #3 (permalink)
Date registered: Apr 2006
Vehicle: 05 slk350, 02 maxima, 02 accord, 99 expedition, 95 eclipse
maybe it's a bomb
tnsr35 is offline   Reply With Quote
Old 11-11-2010, 10:02 AM   #4 (permalink)
Date registered: Nov 2010
I had this same thing happen to me, wound up being a bad piston
Bryant9850 is offline   Reply With Quote
Old 12-11-2010, 08:16 PM   #5 (permalink)
Date registered: Dec 2010
Vehicle: 07' slk 55
what car/engine is this in? sounds like lifter ticking/tapping. once engine warms up the clearances fine and the lifter gets enough oil pressure. Or the secondary air injection turning on which makes a "dieseling" type noise which is normal for the newer vehicles
roadtalontsi is offline   Reply With Quote
Old 01-06-2011, 10:16 AM   #6 (permalink)
Tri-Star's Avatar
Date registered: Aug 2007
Vehicle: C320 4matic
My car also makes a tapping, clicking noise upon start up for a while. I havent had any problems and i've owned the car about 3-4 years.
Tri-Star is offline   Reply With Quote
Old 02-22-2011, 12:31 PM   #7 (permalink)
Date registered: Feb 2011
my car had a ticking nose when i drive but goes away when in N. any ideas?
jlz00 is offline   Reply With Quote
Old 01-06-2012, 12:09 AM   #8 (permalink)
Vehicle: 1993 300E 2.8 (mine), 2012 C250 (wife's), 2004 C230 (sold), 2005 E320 (sister-in-law's)
Question
My wife's car had a similar problem but it only happened once for some reason. Don't know if that was related to cold weather (we always kept the car in the garage though)...anyway, I did notice that we need to add 1.5 qt of oil as the oil level seems to be running low. We just did service B which includes changing oil, but I don't know what type of oil the mechanic changed (I think it's Mobil 1, but not sure if it's 5W40 or something else). If I go buy some Mobil 1 oil can I just top it off? Does it matter to mix two different ratings of engine oil (as long as they are both Mobil 1 synthetic)?? For colder weather what ratings of oil should I use? Thanks!
ohman is offline   Reply With Quote
Old 02-05-2012, 09:46 AM   #9 (permalink)
ponzese's Avatar
Date registered: Feb 2005
Vehicle: 2005 SLK 350/ amg kit
Send a message via Skype™ to ponzese
My SLK 2005 had the problem few years back, was one of the pulley, replaced and the clicking stopped for few years till few mont go. Bring the car in the shop 2 more times kept overnite, replace other parts but not the clicking noise, they told me they don't hear any noise at start at all. Bring my car home, start my car the next morning the noise still there. I have notice the noice only on a moist or rainy day. total bill 1700 $, problem not solved.
SLK 350 - 6 Speed Man-BB - AMG Sport package - Heated seat - Comfort light - Lighting package Entertainment package , DVD Navigation. - Premium package
K-40 Radar detector - front Defuser - Chrome Grills
MB Wind Deflector -
ponzese is offline   Reply With Quote
Bookmarks
Ticking noise from engine when cold, any ideas? aquascape R171 SLK Class 4 02-05-2008 01:00 PM
S500 engine noise when starting cold ec308 W220 S-Class 7 11-11-2006 12:53 PM
Loud ticking noise from engine after parking in slope, front down (hydraulic valve lifter johan6504 W124 E,CE,D,TD Class 1 05-19-2003 08:59 AM
Very loud ticking noise... Chupper G-Class 2 03-15-2003 04:13 PM
loud ticking noise on c320. Guest (MBNZ) W203 C-Class 5 01-20-2002 10:47 PM
