Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Roadster Forums > R171 SLK Class
Old 07-12-2008, 12:44 AM   #11 (permalink)
Supporting Vendor
Date registered: Jun 2003
axxis Ultimas are the best all around street/track dual duty pad. Full ceramic akebonos are NOT recommended for stock rotors, their heat up time creates brake lag and their heat range is way too hot. you want a carbon mettalic or carbon ceramic hybrid pad for the street, not a true full ceramic, its just too much.
omeyhomey is offline   Reply With Quote
Lots of brake pad talk- what seems to be the best bite/low dust/no squeel pad? HACK THT W163 M-Class 14 03-24-2008 08:08 AM
brake pad dejan supić W201 190E, D-Class 2 07-20-2007 07:01 AM
Newb Brake Pad Change, Now Brake Fluid Leaking Jeff619 W126 S,SE,SEC,SEL,SD,SDL Class 10 06-20-2007 05:54 PM
Need Brake Pad Help! NewMBOwner W201 190E, D-Class 10 07-08-2006 05:24 PM
Stupid brake question.... how thick is the oem front/back brake pad?? ometofu W163 M-Class 7 07-11-2002 06:23 AM
