Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Roadster Forums > R171 SLK Class
Old 03-26-2008, 08:04 PM   #1 (permalink)
Date registered: Mar 2008
Vehicle: 2005 SLK 350
"Knocking" shifter on 6 speed manual SLK
I recently purchased a 2005 SLK350 with the 6 speed manual transmission. I noticed that between 3rd and 4th gears, particularly if accelerating or applying a little pressure to the shifter (forward in 3rd, or back in 4th) that I could feel a sort of knocking or pulsing in the stick. Everything still meshed up okay and overall was functioning normally, but (1) this seems a little rough around the edges for a car like this and (2) I worried that it might be a leading indicator of future problems. I'd like to make sure that I take care of issues like these now, while the car is still under manufacturer warranty.
I brought it into the dealer, where they first guessed that it was a synchro problem (which seems odd to me, as the problem occurs AFTER the gear is engaged). After working on it for a week, they told me that they couldn't get a spacer that was necessary to reassemble the transmission and that they would instead be putting in a new one. Great news for me!
Well, I got back the car, and while the 3rd & 4th gear pulsing is gone, now I'm getting the same thing, perhaps slightly worse, in 2nd gear. Again, other than the annoyance of feeling the shifter shaking in my hand, everything basically works okay.
I'm curious. Has anyone else had a similar problem? Were you able to get it resolved? Do any mechanically savvy folks out there have any good ideas?
Thanks in advance.
SouthernSLK is offline   Reply With Quote
Old 03-27-2008, 03:24 AM   #2 (permalink)
-1-
-1-'s Avatar
Vehicle: SLK 55 ///AMG The MONSTER on the block
My wife's SLK 350 is a six speed. Never experienced anything similar to what you described. Ironic that you still have a similar problem with a new transmission, different gear. It will be interesting if anyone else reports the same problem. Hard to imagine that MB replaces entire transmissions after failing to locate a spacer. But, that's good for us. Good luck.
----------------1-----------------
--------SLK 55 ///AMG---------
THE MON55TER ON THE BLOCK
-1- is offline   Reply With Quote
Old 03-27-2008, 11:42 PM   #3 (permalink)
Date registered: Jan 2007
Vehicle: 2003 C240 4Matic
I haven't driven a manual SLK, but I have felt this in other manual cars. As long as the transmission doesn't grind or pop out of gear, I don't think this is a problem.
Whosdis is offline   Reply With Quote
Old 03-31-2008, 11:21 AM   #4 (permalink)
Ynot's Avatar
Date registered: Oct 2004
Vehicle: 06' SLK350
I drive a manual SLK and have not experience anything like it, I suggest you get it fixed before the warranty expires. Or get extended warranty if you decided to keep it after the warranty.
06' SLK 350, Iridium/Ash all pkgs. 6-spd, 19" DCR and other stuff
Ynot is offline   Reply With Quote
Anybody have a "FREE PLUS Postage" SLK Manual ?! danger450 For Sale, Trade & Wanted Items 2 12-26-2007 11:26 AM
"Manual" mode on 7 speed auto SLK350 PhilD73 R170 SLK Class 1 04-24-2006 06:15 AM
Your SLK "Primary" or "Secondary" mode of transportation? 2000 SLK 230 LM R170 SLK Class 23 05-05-2004 09:35 AM
"knocking" sound under the carriage when starting from cold... joeml W163 M-Class 0 12-10-2002 12:58 PM
