Sorry I'm not american/english I did not get it.
What has been stolen?
GernBlansten was referring to the lack of an "H" in the word "Theft." I think he was just trying to make a little joke and was not making fun of your English (which I think is pretty darn good).
Sorry I can't help you out with a solution. Most, if not all, of the SLKs in the states come equipped standard with both Tele-Aid and alarm systems. Haven't heard of anyone trying to retro-fit these systems into their cars. Sounds like that might not be the case in other countries, though.
3 cables you could find:
1 Positive alway On - I think any wire coming out of the driver side fusebox in dashboard are always on - get a add-a-fuse-circuit adapter and piggyback onto any of the fuses
1 Positive On when the car is running - I think you're looking for an IGNITION one, and you can either tap it from the cigarette lighter wire OR there is a fuse in the fusebox in engine bay which only gets turned on when car is on, think its the one marked cigarette lighter/accessory. Same thing as the always on wire, use a add-a-fuse-circuit adapter
1 Negative - easiest of all, just run the wire to any grounded metal point.
Hope that helps
Thank You
I found an always on from CD Changer power supply
Tomorro I'll unplug the cigarette lighter so I take the ignition power from there.
