I know that most of us with the stock audio 20 system of the slk have a very difficult time with trying to find a solution that will allow the installation of an ipod without having to change the stock audio system. A possible solution is this
http://www.dension.com/icelinkgateway500.php
I emailed dension about their product and received the following answer. If you are interested in the product, it would be good to try and contact dension and show that there is indeed demand for their product from slk owners; and that they should try and support the r171 slk audio 20. Email follows:
Hi Josef,
We have not tried on that car during the tests (It is so rare). But if you can send a picture from the head unit and define the differences I will try to answer to your questions.
The product will be available in August.
Regards,
Dension Support
On Wed, 05 Jul 2006 19:54:17 +0200,
josef332@yahoo.co.uk wrote:
> > IP: 87.203.66.60
> > Dear Sir or Madam,
> > I have an slk r171 with the mercedes benz audio 20 installed.I am thinking of getting a dension gateway 500 in order to be able to connect my ipod to the stock audio system
> > I would like to ask:
> > a) Is the gateway 500 combatible with the audio 20 of the slk (which is a bit different from the audio 20 used in the c class and the clk)
> > B) Will it need reprogramming for the MOST network in order to work i.e program it like installing a stock cd changer to the audio 20 using winstar?
> > C) will the gateway 500 need a special adaptor in order to supply it with power
> > D) when will the gateway 500 be available??
> > Kind Regards
