» Site Navigation
» Other Sites
Links
» Tire Upgrade Garage
Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Roadster Forums > R171 SLK Class
Old 04-13-2006, 02:46 PM   #1 (permalink)
Easty
Easty's Avatar
Vehicle: 55 //AMG, Fireblade
Send a message via MSN to Easty
Brake fluid change.
Anyone performd a change yet? The track days I'm doing require for a flush and new fluid every six months. I've bought some castrol SRF and hopefully do it this weekend. And tips in advance? may be a great help.
Thanks loads, Brian
Easty is offline   Reply With Quote
Old 04-13-2006, 04:12 PM   #2 (permalink)
Saaz
Date registered: Nov 2004
Vehicle: '06 SLK55
RE: Brake fluid change.
I've always heard that a pressure bleeder should be used on ABS systems for a thorough flush. (Plus it's supposed to be much easier to use.)
But I don't have much first-hand experience flushing brakes, so that's about all I can tell you.
Saaz is offline   Reply With Quote
Old 04-14-2006, 09:37 AM   #3 (permalink)
dava
Date registered: Mar 2006
Vehicle: SLK200
Send a message via MSN to dava
You realy need a pressure bleeder to do what you want and some times it is necessary to use the star diag to completely bleed the ABS pump.
dava is offline   Reply With Quote
Old 04-14-2006, 10:34 AM   #4 (permalink)
CMiYC
CMiYC's Avatar
Date registered: Jun 2005
Vehicle: '06 SLK55
Send a message via ICQ to CMiYC Send a message via AIM to CMiYC Send a message via MSN to CMiYC Send a message via Yahoo to CMiYC
While I don't recommend not doing the flush, TWS doesn't really require it. (in other words, nobody is going to ask you to prove it otherwise.)
Most of the people don't. Keep in mind that the some of the cars there (the miatas especially) are older cars. I wasn't planning to flush mine until it is 12 months old, even though they want it done every 6.
2006 SLK55 Obsidian Black w/ Black Int
Lighting, 320 Audio, 326 Premium, Airscarf, One Big Ass Smile.
CMiYC is offline   Reply With Quote
Old 04-14-2006, 03:42 PM   #5 (permalink)
slk55er
slk55er's Avatar
Date registered: Sep 2004
Vehicle: 2005 SLK55 AMG
dava - 4/14/2006 10:37 AM
I've not bled the brakes on my SLK55 yet, but I've done it many, many times on many BMWs. Yes, I believe pressure bleeding is necessary and I will plan to use my usual technique -- using my air compressor and my wife's assistance as follows:
I purchased a brake fluid reservoir cap for a VW Sirrocco. It does not have an electrical sensor or wire connector in it -- it is just a plain old screw-on cap. The cap on the SLK55 is similar. (Most BMW caps have a fluid level sensor in them.) I then drilled a 1/2 inch or so hole through it and installed an "L-shaped" air hose fitting to it with some gaskets to minimize air leaks.
First I remove the wheels and make sure I have the correct size wrench -- 7 or 8 mm on a BMW as I recall (flare wrench preferred) and clear hose to connect to the bleeder nipples. The hose should be looped once and inserted into a suitable container (old brake fluid bottle.)
I then use a turkey baster to remove as much old fluid as possible from the reservoir. Fill the reservoir with fresh fluid. (Alternating fluid color from one bleeing to the next makes it easy to see when you have flushed enough fluid through into each caliper.)
Then install the reservoir cap with the air fitting and connect it to a 15psi air hose. Start with the wheel farthest from the reservoir (right rear on US cars). Connect the bleed hose, open the bleed nipple and have your assistant press the pedal to the floor and hold it there while you close the nipple. Then have the assistant allow the pedal to return up to it's normal position. Repeat this as many times as necessary to see fresh fluid entering your hose and then a few more times for good measure. If you see any air bubbles, continue until there are none.
Make sure that the fluid level does not drop in the reservoir enough to draw air into the lines. Check the level a couple of times through the process.
Repeat the process for each wheel, doing the caliper closest to the reservoir last. When done, top up the reservoir with the proper level of fluid and re-fit the wheels.
Wear latex gloves when doing this ( the fluid is toxic) and don't drip or spill any on paint -- it will severely damage paint.
Any additional comments or corrections greatly appreciated.
Gordon Haines
2005 SLK55 AMG (Orion Blue/Beige)
1997 BMW 740i
1974 Fiat X1/9 (Neon Green, Original Owner)
slk55er is online now   Reply With Quote
Old 04-14-2006, 06:35 PM   #6 (permalink)
Easty
Easty's Avatar
Your a star mate, I used to do most of the stuff on my car.. but it's been a while. The reason I'm doing it within 6 months is that a tech form is required to partake in the track days and my friend can sign them off for free. He just asked that the brake fluid be changed within 6 months. Unless it's got some Castrol in it's vains. He used to do a lot of professional racing and this is his only reqest.
Old 04-15-2006, 04:25 AM   #7 (permalink)
Duo-Art
Date registered: May 2004
Vehicle: SLK 350
What is the reason for them requiring you to change brake fluid every 6 months? Does it go bad from the heavy use of the brakes at the track?
Duo-Art is offline   Reply With Quote
Old 04-15-2006, 06:45 AM   #8 (permalink)
Easty
Easty's Avatar
Yes, general fluid boils under extreme use and gets saturaed with air. I was at my friends when he last did his elise and the fluid came out black. I used to change the bike fluid every three months if I was doing a lot of track days. It also deponds on the track, little pokey track with no straights are a lot worst than say TWS which has likea runway after every turn.
