Gorilla vs Mcgard wheel locks? - Mercedes-Benz Forum
post #1 of 9 (permalink) Old 03-09-2006, 01:27 PM Thread Starter
Ynot's Avatar
Date registered: Oct 2004
Vehicle: 06' SLK350
Anybody have any input on which is better. I ordered Mcgard ultras ($100 from the dealer) and had to cancel the order b/c the part# Ianx provided was for the standard ball seat lugs that comes with the SLK, since I have aftermarket wheels and now use gorilla cone seat lugs I need to either find a new part# for my dealer or get some Gorilla wheel locks from Discount. ($30)
I don't mind spending more for better wheel locks, was wondering if any of the members here have any experience with either. If Mcgard is better, then I have to do some research to find the right ones that will fit. If Gorilla's are better, all I have to do is head down to Discount and pay them 30 bucks. opinions, advised, suggestions appreciated.
06' SLK 350, Iridium/Ash all pkgs. 6-spd, 19" DCR and other stuff
Ynot is offline
post #2 of 9 (permalink) Old 03-09-2006, 01:38 PM
Easty's Avatar
Vehicle: 55 //AMG, Fireblade
Send a message via MSN to Easty
RE: Gorilla vs Mcgard wheel locks?
I got the mcguard standards for the stock wheels. I fitted them last nigtht and the bolt heads in these wheels are really recessed..I was worrying about marking the wheels with the wrench. not sure about the differece between the ultra's and the standard. the way they tend to get these things of is by hammering a socket over it. I'm guessing the sleeve on the ultras would buckle in easier than the reinforced heads on the standards.. would this sleeve then rotate still or give enough to undo it. Anyhow it's just a extra precaution I'd go for the mc guard for the simple reason they seem hard to get hold of. so the key is a little harder to get for the lightweight theif..
Easty is offline
post #3 of 9 (permalink) Old 03-09-2006, 04:28 PM
CMiYC's Avatar
Date registered: Jun 2005
Vehicle: '06 SLK55
I recommend using both.
When I use wheel locks, I don't use the same one for all 4 tires. Theives can defeat anything, but time. The more time they have to spend at your car, the less they will want to take things.
2006 SLK55 Obsidian Black w/ Black Int
Lighting, 320 Audio, 326 Premium, Airscarf, One Big Ass Smile.
CMiYC is offline
post #4 of 9 (permalink) Old 03-09-2006, 04:47 PM
Date registered: Jul 2005
Vehicle: 2006 SLK 350
Good idea. If cost is not an object, the best thing to do would be to buy four sets with a different lock on each wheel. [;)] I suspect that SLK car club members probably do just that.
2006 SLK 350. Black/Black; 7-speed AT; Comfort, Heating, Lighting, and Premium packages
NewMB is offline
post #5 of 9 (permalink) Old 03-10-2006, 09:06 AM Thread Starter
Ynot's Avatar
Vehicle: 06' SLK350
The gorilla lug nuts that I have now uses a special key to take out, getting another set of wheel locks would mean I have two sets of locks. I'm just going to stick with Gorilla wheel locks. Thanks for the input. If they really want it, they will tow it away. [:D]
Ynot is offline
post #6 of 9 (permalink) Old 07-28-2006, 10:14 PM
Vehicle: 2007 SLK350, Storm Red, Premium 1 Pkg, Bi-Xenon Lights, Heated Seats, Airscarf
Can you point me to an online source for the McGuard standards? I've
found a couple, but they don't list Mercedes, much less the SLK.
Also, when I read the McGard website, they indicate that there are
multiple combinations of keys. Not just one key fits all. Is that correct?
Thanks,
Mike
easygreenus is offline
post #7 of 9 (permalink) Old 07-29-2006, 04:34 AM
Corkscrew's Avatar
Date registered: May 2005
Vehicle: 2009 BMW Z4, 2005 SLK 200, 2004 S 280
How do these wheel locks actually work? I don't think I have ever seen them. Do they just replace one bolt or all the bolts on a wheel? Any photos?
2009 BMW Z4, 2014 MB 300S BLUETEC HYBRID, 2005 MB SLK 200
Corkscrew is offline
post #8 of 9 (permalink) Old 07-29-2006, 05:03 AM
steve-p's Avatar
Date registered: Jul 2004
Vehicle: BMW
Normally you just replace one bolt per wheel. However, you could buy more than one make, and then replace two (or more) of the bolts per wheel with different ones.
steve-p is offline
post #9 of 9 (permalink) Old 07-29-2006, 06:32 AM
Easty's Avatar
Thanks,
Mike
I got them through amazon, don't remember waht the retail company was called they came from. I'll check and post when I get back to the US. I think there was another thread where I already posted the links.
AN englishman in fort worth
Easty is offline
  Mercedes-Benz Forum > Mercedes-Benz Roadster Forums > R171 SLK-Class
