Please, does anyone have already change the oil of his SLK 200K?
I would appreciate some details to know where is located the drain plug on the 271 engine, and if you have some pictures i would perfect.
Thank you in advance... [:)]
I don't have personal experience with the SLK200. But, I have to believe that you will have to remove the plastic panels from below the engine compartment to access the drain plug. Just like all the other SLKs. Once you remove the panels the drain plug location should be obvious.
