Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Roadster Forums > R171 SLK Class
Old 01-10-2006, 12:43 PM   #1 (permalink)
dixiebenz's Avatar
Date registered: Jan 2006
Vehicle: SLK 350
Air & Cabin Filters
As a new owner, I suppose I am going to be asking questions for a while. Hope nobody minds.
I would appreciate some help on removing the rear engine cover. The front cover is easy to remove but I'm afraid I will break something by just trying to pry it off. I want to check the air filter which I assume is under there. Also does anyone know the cabin filter(s) location and the part numbers for them?
dixiebenz is offline   Reply With Quote
Old 01-11-2006, 02:19 AM   #2 (permalink)
ukblueyes's Avatar
Date registered: Apr 2005
Vehicle: SLK 350+ GSD350 CONV
RE: Air & Cabin Filters
dixiebenz - 1/11/2006 8:43 PM
I don't think you have a rear engine.
If you have... i think they've sold you a Porsche. [;)]
Sorry, I couldn't resist.
Welcome to the forum, somebody sane will be along with the correct answer in a minute. [:)]
ukblueyes is offline   Reply With Quote
Old 01-11-2006, 07:36 AM   #3 (permalink)
Ynot's Avatar
Date registered: Oct 2004
Vehicle: 06' SLK350
Here's the how to for the air filter, I'm not sure about the cabin filter.
http://www.euroteckmotorsports.com/index.cfm?id=29195&fuseaction=browse&pageid=84
06' SLK 350, Iridium/Ash all pkgs. 6-spd, 19" DCR and other stuff
Ynot is offline   Reply With Quote
Old 01-12-2006, 08:41 AM   #4 (permalink)
Shinigami's Avatar
Vehicle: SLK 55 AMG
Yup, the rear cover portion is removed quite simply by just nudging it upwards after removing the two tubes that feed air into it form the front.
My rear cover piece was also attached at the back right hand corner with some plastic strip to an other tube. Not sure why, but my guess is it's done to keep the tube from moving about.
New car: 2004 SLK 55 AMG, Iridium silver.
Additional: Chrome door lock pins, K&N Performance Filters, Piecha roof control module
Sold: 1998 SLK 230K, Linarite blue.
Brabus: Front spoiler, side skirts, rear apron, exhaust, gear shift + hand brake, 17" Monoblock IV, hubcaps/wheel locks, Aluminium doorlock pins, polished safety roll bars, Brabus logo
Digit-Power: 30bhp + 50nm torque
Additional: Chrome side indicator frames, Chrome SRS badges, CLK grill, Lorinser Wing, Rieger headlight covers
Shinigami is offline   Reply With Quote
Old 01-12-2006, 04:25 PM   #5 (permalink)
dixiebenz's Avatar
Vehicle: SLK 350
Thanks for the link and responses but you guys have 55's and the covers are somewhat different. I have a 350. Is the removal the same?
Old 01-12-2006, 04:54 PM   #6 (permalink)
Ynot's Avatar
Vehicle: 06' SLK350
dixiebenz - 1/12/2006 5:25 PM
It's similiar as I recall SLKfromOakley replaced it, IIRC.
Old 01-12-2006, 09:39 PM   #7 (permalink)
SLKfromLOKEY's Avatar
Date registered: Nov 2005
Vehicle: 06 SLK55 Performance
dixiebenz,
Believe it or not the SLK350 uses the same exact filters as the 55 AMG's do, the airbox is removed in a similar fashion. When I removed the airbox on my SLK350 I too was worried about breaking something, if you inspect your airbox thoroughly you will notice a latch that holds the middle of your airbox down, this latch is located at the top of the airbox near the windshield of your car. Once you unfasten this clip you will be able to just lift the airbox off, I would lift from one corner and work my way around the entire airbox, this airbox just sort of snaps in and is very easy to take off. Please be sure to remove any hoses and the airducts. The part number for the airfilters: A112 094 00 04 I have included a picture with some more detailed information, I hope this helps.
Ynot,
I don't know who SLKfromOakley is but I hope I can help.[;)]
I hope this helps,
SLKFROMLOKEY
SLKfromLOKEY is offline   Reply With Quote
Old 01-13-2006, 07:03 AM   #8 (permalink)
Ynot's Avatar
Vehicle: 06' SLK350
SLKfromLOKEY - 1/12/2006 10:39 PM
Ynot,
I hope this helps,
SLKFROMLOKEY
lol.. I guess I didn't recall correctly, next time instead of IIRC, I should use IIDRC.
Old 01-16-2006, 10:33 AM   #9 (permalink)
LETO's Avatar
Date registered: Jan 2005
Vehicle: 07 GL450 PE, 06 SLK55
What is the advantage of changing air filters. What brand of filters should i look into?
LETO is offline   Reply With Quote
Old 01-16-2006, 10:37 AM   #10 (permalink)
Julien's Avatar
Vehicle: 06 SLK 55 Firemist
LETO - 1/16/2006 1:33 PM
With mostly top down driving none.[:D]
Past: 01 Honda S2000 New Formula Red/Black, Work's 18" wheels
Gone: 05 SLK 350, Mars/Beige, Comfort, Lighting, Entertainment w/Nav, AMG Sport, Heating, Premium
Have: 06 SLK 55 AMG, Firemist/Black, Airscarf, Lighting, Entertainment w/Nav, Premium
Want: 09 SLK 63 AMG, Orion/Ash, Airscarf, Lighting, Entertainment w/Nav, Premium, Panorama roof
Julien is offline   Reply With Quote
