Last night I was driving and had to make a tight merge from a stop so I floored it. I was in "S" mode. As expected, it changed from 1st to 2nd at the redline, but when it came time to hit 3rd at the redline the rev limiter kicked in and there was no power. A bit disconcerting. Has anybody else experienced something like this?
When turning the AMG 55 holds the gear to keep in the power band and prevent an unwanted upshifts. In almost all cases you accelerate before a turn. So this is normal in the 55 and you would need to upshift in order to make it change.
Past: 01 Honda S2000 New Formula Red/Black, Work's 18" wheels
Gone: 05 SLK 350, Mars/Beige, Comfort, Lighting, Entertainment w/Nav, AMG Sport, Heating, Premium
Have: 06 SLK 55 AMG, Firemist/Black, Airscarf, Lighting, Entertainment w/Nav, Premium
Want: 09 SLK 63 AMG, Orion/Ash, Airscarf, Lighting, Entertainment w/Nav, Premium, Panorama roof
Could have also been traction control limiting the revs. You do not want to accelerate hard with the 55 during corner. The car is very nose heavy, which will cause the backend to lose traction easily.
2006 SLK55 Obsidian Black w/ Black Int
Lighting, 320 Audio, 326 Premium, Airscarf, One Big Ass Smile.
There are a number of things that cause you to lose traction. I'm inclined to believe you had a momentary loss of traction (not enough to cause the warning beeps) which is why you lost power.
Did you see the Carret (^) on the dash display? (Like when you overrev in manual.)
Location: Spring (near Houston), in the Great State of Texas
RE: Unexpected Transmission Behavior
I have also hit the redline. I think the auto should shift before the redline, no matter what. After all, it's all computerized so the RPMs are always known.
