Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Roadster Forums > R171 SLK Class
Old 10-25-2005, 08:13 PM   #11 (permalink)
AMG&AMG's Avatar
Date registered: Jul 2005
Vehicle: SLK 55 AMG
RE: Best tires for 235/35/19 and 265/30/19?
I told you guys PS2 [:D][:D][:D]
Ynot, get your info. correctly..
AMG&AMG is offline   Reply With Quote
Old 10-25-2005, 08:37 PM   #12 (permalink)
Date registered: Aug 2004
I know the guy who owns this car and the tires DO rub on the passenger side. The sidewall of the tire was getting torn apart.
This iS FACT.
The rubbing occurs when going over bigger bumps or potholes. Problem can be cured by slightly rolling the fender.
Ynot is right on this one.
Gatecrash - 10/22/2005 12:18 PM
this is 19" AMG wheels with PS2
big_willy is offline   Reply With Quote
Old 10-26-2005, 09:41 AM   #13 (permalink)
Ynot's Avatar
Date registered: Oct 2004
Vehicle: 06' SLK350
AMG&AMG - 10/25/2005 8:13 PM
I did, vertified it with a few ppl, it will rub if you lower it, sounds like it rubs if you don't lower it, thanks big_willy.
Rsbslk will tell you that he had to roll his fenders for it to work.
So get your info correctly b4 you reply. [:p][:D]
06' SLK 350, Iridium/Ash all pkgs. 6-spd, 19" DCR and other stuff
Ynot is offline   Reply With Quote
Old 10-26-2005, 02:37 PM   #14 (permalink)
EDSLK's Avatar
Date registered: May 2005
Vehicle: SLK350 and SL500
Send a message via AIM to EDSLK
ALight, since i have both i am going to jump in and give me 2 cents. In the case of tires, all of you are somewhat correct with your replies. If you do not lower the car, the PS2 should be fine and won't rub on 19" wheels. If you do lower the car, you will have a higher chance of rubbing with PS2 tires. PS2 sidewalls are thicker than Falken/Toyo tires. In fact, i think they are the thickest i have seen. The sidewalls do matter because in the case of lowering with 19" wheels on our vehicle, because it really is that close to rubbing. I have 19" wheels, lowered with brabus springs, with PS2 tires, and i have recently rubbed when going high speeds on freeways as well as large dips. under normal driving conditions i do not rub at all. keep in mind, i have the most aggressive offset you can have for this vehicle. my recommendation for not rubbing with 19" wheels lowered- get correct offsets, do not got to the extreme on custom offsets, go with either falken/toyo tires, and get some shocks for the vehicle. The brabus springs are really soft and the car tends to "float" and not be as stiff as the normal sport suspension. Coilovers with shocks should be fine as well. Hope this helps...
EDSLK is offline   Reply With Quote
Old 10-26-2005, 04:54 PM   #15 (permalink)
Ynot's Avatar
Vehicle: 06' SLK350
Thanks EDSLK, I was kinda waiting for your reply as I recall you do have both (lower springs and PS2's). All the other ppl that has PS2's w/o rubbing I've noticed didn't have springs.
Old 10-26-2005, 05:42 PM   #16 (permalink)
zaint10's Avatar
Date registered: Dec 2004
Vehicle: SLK55, SL6.1, M3
Send a message via MSN to zaint10
What about 19inch 235/265 with PS2 on the SLK55 would they rub~?? Thanks!
zaint10 is offline   Reply With Quote
Old 10-26-2005, 06:46 PM   #17 (permalink)
Ynot's Avatar
Vehicle: 06' SLK350
zaint10 - 10/26/2005 5:42 PM
Without drop yes but a little rubbing, with drop, yes with little rubbing but as EDSLK stated above, with correct offset it might work. I've called several places and it's not recommended, they said if you are going to lower your car, get toyos or nitto's.
