» Site Navigation
» Other Sites
Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Roadster Forums > R171 SLK Class
Old 10-07-2005, 01:53 PM   #1 (permalink)
Date registered: Apr 2005
Where is there a permanent 12V supply to wire a radar detector?
I would like to hardwire a radar detector into my car. The manufacturers have told me i need to connect the two wires, one to a PERMANENT 12V+ supply and the other to a 12V- supply.
Where coudl i connect these two, how about the 12v accessory plug in the passenger footwell. Does anyone know which wires are which?
Shoudl i add an inline fuse, manufacturer thought non necessary but i was not so sure?
Any help much appreciated.
slk350driver is offline   Reply With Quote
Old 10-07-2005, 02:15 PM   #2 (permalink)
CMiYC's Avatar
Date registered: Jun 2005
Vehicle: '06 SLK55
Send a message via ICQ to CMiYC Send a message via AIM to CMiYC Send a message via MSN to CMiYC Send a message via Yahoo to CMiYC
RE: Where is there a permanent 12V supply to wire a radar detector?
An inline fuse wouldn't hurt if you're using the accessory plug. They provide enough current to burn out your detector (unless a fuse is built in) before its fuse would blow.
You need +12V and Ground ("negative" in cars), not "-12V". -12V and Ground (negative) are very different. I haven't seen the accessory plug's wiring yet but the standard in cars is: Red is +12V (positive) and Black is Ground (negative).
2006 SLK55 Obsidian Black w/ Black Int
Lighting, 320 Audio, 326 Premium, Airscarf, One Big Ass Smile.
CMiYC is offline   Reply With Quote
Old 10-07-2005, 02:37 PM   #3 (permalink)
bloflin's Avatar
Date registered: Dec 2004
Vehicle: 2005 SLK55 AMG
CMiYC - 10/7/2005 4:15 PM
? A power source (car electrical system) only provides the current drawn by the device. It can't push current at the device. A fuse protects the electrical system from the device overloading the electrical system. A fuse does not protect the device.
This is not to say, having a fuse isn't a good idea. It would prevent your car fuse (or relay) from blowing if the radar detector power cord was pinched and shorted together or the detector itself developed an internal short.
bloflin is offline   Reply With Quote
Old 10-07-2005, 03:14 PM   #4 (permalink)
fgwinn's Avatar
Vehicle: SLK350, E500 4matic
Are you sure it calls for permanent and not switched? I would think you would want power switched with the ignition so that you don't run down the car battery if you forget to power off the radar detector.
slk350driver - 10/7/2005 4:53 PM
... one to a PERMANENT 12V+ supply and the other to a 12V- supply.
fgwinn is offline   Reply With Quote
Old 10-07-2005, 03:36 PM   #5 (permalink)
Date registered: Nov 2004
Vehicle: '06 SLK55
Yes, the accessory plug works. I thought red/black was a pretty universal standard, but at least on my accessory plug, I think brown = ground and black/white striped = +12V. It wouldn't hurt to double-check with a meter.
As the others said, the fuse is optional when you're tapping into an existing, fused circuit. But an extra fuse won't hurt if it makes you feel better.
But I'd like to clarify one thing in your post: the request for a "permanent" +12V supply. The accessory plug is switched with the ignition key, so it cuts off when you turn off the car. That's typically what you want for a detector. There ARE many circuits in the car that are always on, even when the ignition is off, but wiring a detector into them would risk draining your battery. Do you have some kind of detector that really requires power all the time? (GPS-based computer or something?)
Gordon and I have posted descriptions and pics of our hardwiring efforts. Here are the links, or you can search for "V1" if these links don't work.
http://www.benzworld.org/forums/forums/thread-view.asp?tid=1216877&posts=13
http://www.benzworld.org/forums/forums/thread-view.asp?tid=1199800&posts=10
Saaz is offline   Reply With Quote
Old 10-08-2005, 01:37 AM   #6 (permalink)
aquascape's Avatar
Vehicle: Mercedes SLK55 AMG
I think there is a permanent 12V supply feed going to the back of the upper control panel control unit (N72/1) (the unit with the heated seat,airscarf etc buttons on)
SLK55 AMG, Cubanite Silver, Nappa, Multiregion unlocked comand
Retrofitted: Rain sensor wipers, ipod kit, brabus mini antenna, chrome door pins, folding mirrors, mods4cars roof module, Auto dimming interior mirror, paddle shift steering wheel
OLD CARS
SLK 350 , SLK 230K, MR2, Mitsubishi GTO 3000
aquascape is offline   Reply With Quote
Old 10-08-2005, 12:19 PM   #7 (permalink)
CMiYC's Avatar
Vehicle: '06 SLK55
I think the instructions are calling for Permanent as in always physically available. If it was calling for constant 12V supply, then I'd start assuming they don't want switched power.
