Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Roadster Forums > R171 SLK Class
Old 09-05-2005, 04:41 PM   #1 (permalink)
Date registered: Jul 2004
rear rattles
I had a cracking type noise in the rear when I went around a corner. This was now traced to a defective rear tie bar that moved in it's bushings. This took 3 days to discover and two previous trips to the dealer. I was to pick up the car but now they say that the front struts are to be replaced as well. Car will be there another 3 days. Hope you do not have this problem. They originaly thought the rear noises were coming from the roof and tried to lube that for a fix. Please have them check the rear tie bar if this does not work. Their comment was that "this has not happened before" maybe.
ron h is offline   Reply With Quote
Old 09-06-2005, 02:42 PM   #2 (permalink)
aquascape's Avatar
Date registered: Nov 2004
Vehicle: Mercedes SLK55 AMG
RE: rear rattles
I get a knocking noise from the rear when going over bumps and round corners. Must take it Mercedes come time and see what they say. Sounds like the boot is loose or something
SLK55 AMG, Cubanite Silver, Nappa, Multiregion unlocked comand
Retrofitted: Rain sensor wipers, ipod kit, brabus mini antenna, chrome door pins, folding mirrors, mods4cars roof module, Auto dimming interior mirror, paddle shift steering wheel
OLD CARS
SLK 350 , SLK 230K, MR2, Mitsubishi GTO 3000
aquascape is offline   Reply With Quote
Old 09-07-2005, 05:58 PM   #3 (permalink)
RE: rear rattles
Check on the rear anti-roll bar. That was what was causing my problems. The car was unloaded when going around corners. RH
Old 09-08-2005, 05:56 AM   #4 (permalink)
aquascape's Avatar
RE: rear rattles
Is this something i can check myself or do Merc need it
