Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Roadster Forums > R171 SLK Class
Old 07-23-2005, 12:36 PM   #21 (permalink)
Date registered: Jun 2005
Vehicle: 2006 SLK350
RE: IPOD Integration Kit
$700! It's really $1000 when you add on the cost of the iPod..Sheesh!
bmetz is offline   Reply With Quote
Old 08-03-2005, 05:45 PM   #22 (permalink)
samhmbz's Avatar
Date registered: Oct 2004
Vehicle: W211.056C209W202W124
HERE IS A PHOTO OF THE IPOD INSTALLED WITH THE "OPTIONAL" CRADLE IN A SLK.
SAM
samhmbz is offline   Reply With Quote
Old 08-03-2005, 06:14 PM   #23 (permalink)
malibuite's Avatar
Date registered: Dec 2004
Vehicle: 350 SLK
samhmbz - 8/3/2005 5:45 PM
SAM
Is this the MB Integration Kit or OEM? If the MB kit, where did you have it done in SoCal? I have called three dealers and they have all told me the kits are not available yet.
The MB kit showed the IPOD in the drop down compartment held with the elastic band. What holds the Ipod in the location you are showing if you don't purchase the "optional" cradle?
malibuite is offline   Reply With Quote
Old 08-03-2005, 06:36 PM   #24 (permalink)
samhmbz's Avatar
THIS IS A PHOTO FROM THE INSTALLATION INSTRUCTIONS.(IM A MBZ TECHNICIAN)
THE KIT SHOULD BE AVALIABLE AROUND 8-15-05. THIS IS A MB OEM KIT.
SAM
Old 08-04-2005, 04:30 AM   #25 (permalink)
BenzWorld R171 Host
ianx, manchester's Avatar
Vehicle: SLK350
samhmbz - 8/3/2005 9:36 PM
SAM
Hi Sam, many thanks for this posting
In your opinion, is it really a 3 hour install!!!
also are there alternative locations to have the ipod mentioned in the installation details?
Thanks
PS your CAPS LOCK key seems to be broken ;-)
ianx, manchester is offline   Reply With Quote
Old 08-04-2005, 05:23 AM   #26 (permalink)
two dogs's Avatar
Date registered: Sep 2004
Vehicle: SLK 200K
ianx, manchester - 8/5/2005 9:30 PM
Sam in your opinion, is it really a 3 hour install!!!
G'day Ian,
Congratulations on getting the "gig" as moderator; with your knowledgeable but unassuming style, you're sure to be well received.
After having seen the renowned Steve Krabbbenborg remove the COMAND head unit and lay bare the centre console area on my car within a few minutes, I'd feel ripped off if the installation of the iPod kit took more than half an hour!
I'd expect that it could be fitted in any location, within reach of the supplied harness, or further with modification. The location in the diagram is fine with me; at least it's in a lockable location, and will "work" for our USA friends with the CD changer in the glove box.
Cheers
---Julian
two dogs is offline   Reply With Quote
Old 08-04-2005, 05:53 AM   #27 (permalink)
malibuite's Avatar
Vehicle: 350 SLK
two dogs - 8/4/2005 5:23 AM
G'day Ian,
Cheers
---Julian
Yes, but I have the CD changer in the glovebox so if the location showed in the picture is the center console box that is bad news for me because that is where I currently store a lot of stuff I cannot get in the glovebox. [V] Thought the rear dropdown glovebox was an excellent spot since I don't use that for anything.
Old 08-04-2005, 06:52 AM   #28 (permalink)
two dogs's Avatar
Vehicle: SLK 200K
malibuite - 8/5/2005 10:53 PM
Yes, but I have the CD changer in the glovebox so if the location showed in the picture is the center console box that is bad news for me because that is where I currently store a lot of stuff I cannot get in the glovebox. Thought the rear dropdown glovebox was an excellent spot since I don't use that for anything.
G'day malibuite,
As you may (or may not) recall, I was one of the early proponents of the "rear drop down glovebox" location, saying that there was a "punch out" at the back, ready for a connector. However, I've since learned that that was for "emergency" access to a roof mechanism release valve, so I'll recant.
I'm glad it will go in the centre(er) console, which is lockable. I'll be moving less expensive stuff like SunScreen to the "drop down" to make way for it.
Cheers,
---Julian
Old 08-04-2005, 07:54 AM   #29 (permalink)
Vehicle: slk 55
I'm about to buy my wife an Ipod, and I'm sure she will want to integrate it into the car if we are able to. Will the integration kit work with all Ipods currently on the market? Our car has COMAND, does that make any difference? Thx for your help.
shark22 is offline   Reply With Quote
Old 08-04-2005, 08:07 AM   #30 (permalink)
BenzWorld R171 Host
Vehicle: SLK350
shark22 - 8/4/2005 10:54 AM
The kit will work with Ipod 3G, Ipod 4G, including colour screen models, and all ipod minis. (basically any ipod with the 'dock connector')
It will not work with Ipod Shuffles.
