» Site Navigation
» Other Sites
Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Roadster Forums > R171 SLK Class
Old 08-10-2005, 08:23 PM   #21 (permalink)
dsb
dsb's Avatar
Vehicle: '06 SLK55
Send a message via AIM to dsb
RE: Hows do you like the paddle shifter on the auto t
dsb - 8/9/2005 11:54 PM
B) Holding the downshift paddle or gear level is supposed to make the transmission switch to the optimal gear. I thought that it would jump several gears if necessary (ie 7th to 4th gear). However, this only seems to work if you are driving in "D" mode and mash the throttle down. When I use the paddle or pull left on the gear and hold it; the transmission will go to the optimal gear but first downshifts to all others in between (ie 7th to 6th to 5th to 4th). Is this right?
So does anyone else experience the 'additional' gears when getting to the optimal gear?
dsb is offline   Reply With Quote
Old 08-10-2005, 10:23 PM   #22 (permalink)
Date registered: Feb 2005
Vehicle: SLK 350 Diamond blue
I got the optional shifts on the column , just cos it felt cool to flick up and down with my hands on the wheel.
My car has S, C AND M mode , but to be honest I find it much easier to floor it whilst in S and hang on.
Still getting used to it tho. Who knows, I may find it useful later on...
AshleyF is offline   Reply With Quote
Old 08-11-2005, 07:15 AM   #23 (permalink)
Snowball's Avatar
Vehicle: SLK350 AMG Sport
dsb - 8/10/2005 10:23 PM
No, but this is assuming that you hold the shifter before hitting the gas.
Snowball is offline   Reply With Quote
