Setting the time / clock - Mercedes-Benz Forum
post #1 of 15 (permalink) Old 01-17-2005, 11:25 AM Thread Starter
Date registered: Jan 2005
Vehicle: R171 200K
Hi
I'm trying to set the time on my 200K, it is currently one hour forward. Everytime i try to set this back an hour it never works. I also don't seem to have an option for automatic daylight savings adjustment which is supposed to appear according to owners manual. I'm in the UK.
Can anyone help?
Cheers
R171200K is offline
post #2 of 15 (permalink) Old 01-17-2005, 12:08 PM
owen's Avatar
Vehicle: R171
RE: Setting the time / clock
Without actually sitting in the car, I seem to remember that you search the speedo screen menus using the steering wheel buttons. You will eventually find the digital clock in one of the menus, then you adjust the time using the steering wheel buttons. Then, to change the analogue clock, you simply press the reset button on the outside of the speedo casing [left hand side]. You will then see the hands rotate both back and forth before settling at the time you have set. Have a play and it will work?
Ojonesyo
owen is offline
post #3 of 15 (permalink) Old 01-17-2005, 12:17 PM Thread Starter
Vehicle: R171 200K
I wasn't sealing the deal with the reset button.
Its set correctly now.
Ta Owen
R171200K is offline
post #4 of 15 (permalink) Old 01-17-2005, 11:49 PM
huu
huu's Avatar
Date registered: Sep 2004
Vehicle: SLK 200K
i got it set no problem, now HOW TO DISPLAY IT?? digitally with date and year like my other can
huu is offline
post #5 of 15 (permalink) Old 04-03-2006, 03:11 PM
Date registered: Jul 2005
Vehicle: 2006 SLK 350
owen - 1/17/2005 11:08 AM
Hey Owen - Many thanks for your detailed instructions re: resetting the analog clock. Is it just me? I looked all through the owner's manual and couldn't find any specific directions for those of us who do not have the Command system. With your help, it only took me a couple of minutes to re-set the analog clock to DST. [:)]
2006 SLK 350. Black/Black; 7-speed AT; Comfort, Heating, Lighting, and Premium packages
NewMB is offline
post #6 of 15 (permalink) Old 04-03-2006, 03:46 PM
mtiede's Avatar
Date registered: Oct 2005
Vehicle: SLK 350 (2006)
huu - 1/18/2005 1:49 AM
I snickered at that. As I switch between my Toyota van and the Benz, I usually give the whole dashboard a scan looking for the location of the digital clock. Then I realize it doesn't have one [:)]
mtiede is offline
post #7 of 15 (permalink) Old 04-03-2006, 04:08 PM
I thought the analog clock would be controlled with a simple stalk that you rotated, like other cars. It's a much cleaner approach, though, with the sealed lenses on the instrument cluster. Pretty cool that it's synchronized with the digital control settings. Haven't seen that before with my Lexus and BMW. Guess that's one of the reasons why we pay the big bucks for this car, eh? [;)]
NewMB is offline
post #8 of 15 (permalink) Old 04-04-2006, 11:19 AM
etyu's Avatar
Date registered: Mar 2006
Vehicle: 2008 SLK55 AMG
page 140 of owner's manual states to press R (reset) button to confirm the settings after setting the time.
It will also show up on the display, to press R, when setting the time.
I hope this clarifies it. I've learned a lot from the forums.
2008 SLK 55, Pewter, Beige Nappa leather interior
mod R170 antenna, cargo tray, OEM Lexan windschott, stainless steel trunk handle, aluminum doorlock pins
PIAA 5W Super White parking lamps
SmartTop v1.0, Kleyman 3BFM V1.5 (Noregrets Custom Works)
etyu is offline
post #9 of 15 (permalink) Old 04-04-2006, 12:31 PM
Easty's Avatar
Vehicle: 55 //AMG, Fireblade
Send a message via MSN to Easty
I didnt have to do the reset. I think as long as you have sycronize with command set on the menu. soon as you press back on the command after altering the time it changes. Just didn't mine cool little inteligent thing.
Easty is offline
post #10 of 15 (permalink) Old 04-04-2006, 01:35 PM
etyu's Avatar
Pressing the R button after setting the clock applies mainly to those without the COMAND system.
etyu is offline
  Mercedes-Benz Forum > Mercedes-Benz Roadster Forums > R171 SLK-Class
