r170/w202/eaton m62 clutch removal - Mercedes-Benz Forum
post #1 of 24 (permalink) Old 06-17-2013, 12:48 PM Thread Starter
thedose's Avatar
Date registered: May 2010
Vehicle: 1999 C230K
I've searched and read many posts on the r170/w202/eaton m62 supercharger, not only on here, but on the internet... there was even a post on benzworld on how to replace the bearing...
I have a 99' w202, but same engine as the slk230 - the m111.975 - now, on to my question: I bought a brand new clutch assembly for the kompressor and want to replace it, I just serviced all of the tensioners, pulleys, and belts and was going to replace the s/c clutch and pulley as part of that, unfortunately, I was unable to get the s/c out, and tried getting the clutch off with the s/c mounted on the engine - was also unsuccessful as in all of my attempts, the clutch would just spin, I tried using the old serpentine belt to hold it, tried vice grips, no luck.
My question to you: how/what's the best way of removing the clutch assembly? DO i have to remove the s/c - is this easier? Would I need something to put between the rotors in the back to stop the clutch/rotors from rotating when I attempt to unscrew the 8mm bolt on the front of the "unidamp" clutch?
Please advise!
thedose is offline
post #2 of 24 (permalink) Old 06-17-2013, 03:04 PM
dandywarhol's Avatar
Date registered: Nov 2012
Vehicle: 1999 SLK230
Quoted: 4 Post(s)
Send a message via Skype™ to dandywarhol
Disconnect the barrel shaped two pin plug and put 12v/earth directly to the clutch? That'll engage it to remove the bolt.
Whale oil beef hooked!
dandywarhol is offline
post #3 of 24 (permalink) Old 06-17-2013, 03:12 PM Thread Starter
thedose's Avatar
Vehicle: 1999 C230K
where do I get the 12v/earth from? external source?
thedose is offline
post #4 of 24 (permalink) Old 06-17-2013, 03:35 PM
Quoted: 4 Post(s)
Yep. Probably best to disconnect your car battery just to be super safe...................
Just realized, I drove past your way about 7 years ago when heading down to Richlands, south of Roanoke, nice part of the world. Lot of Scottish named places over there too........................
post #5 of 24 (permalink) Old 06-17-2013, 03:51 PM Thread Starter
thedose's Avatar
Vehicle: 1999 C230K
I just recently moved here in October 2012, some parts actually remind me a lot of the black forest in west Germany...
thedose is offline
post #6 of 24 (permalink) Old 06-17-2013, 04:28 PM
Subby_'s Avatar
Date registered: Jan 2007
Vehicle: 1998 SLK 230
Quoted: 37 Post(s)
the by the book method is to remove the electrical plug from the clutch and apply a 12v source to it. this will cause it to engergise and then it wont spin and you can undo the 8mm bolt holding it.
its not a good idea to jam stuff in the rotors as you can scratch them or put excessive force on the bearings inside...
- ASP pulley kit
- 87mm supercharger pulley
- Ported Eaton M62 supercharger
- Ported supercharger inlet manifold
- MAF screen & throttle body screen delete
- Automatic intercooler spray kit
- Single 2.5" Magnaflow Hi-flow cat
- Magnaflow rear muffler + Lukey Ultraflo resonator
- Shift-I progressive shift light
- Custom ECU tune
- Air box delete (custom) with BMC airfilter
- 10c degree STAR thermo fan mod
- FireStorm igntion coil booster
- 5 Bar fuel pressure regulator
Subby_ is online now
post #7 of 24 (permalink) Old 06-17-2013, 11:56 PM
Quoted: 4 Post(s)
I must get a copy of the manual sometime. The cd I got with the car only works with Windows XP
post #8 of 24 (permalink) Old 06-18-2013, 09:49 AM Thread Starter
thedose's Avatar
Vehicle: 1999 C230K
The Bentley manual says to "use the old serpentine belt to hold the clutch and remove the 8mm bolt" (which I tried)
thedose is offline
post #9 of 24 (permalink) Old 06-18-2013, 09:52 AM Thread Starter
thedose's Avatar
Vehicle: 1999 C230K
Yes, I understand this. There is a german tutorial on how to fix it and per the instructions in that, the guy actually used the rubber handle of a hammer and stuffed it in the rotors to unscrewed the bolt. My reaction to reading that was and I was hoping there would be a more professional way of going about it.
Ok, so where can I get 12v of power then? and if I understand it correctly, the cylindrical power plug for the s/c has 4 pins, where would the connections go?
thedose is offline
post #10 of 24 (permalink) Old 06-18-2013, 03:01 PM
Quoted: 4 Post(s)
I'm sure there's only 2 wires in the barrel connector.
Remove the neg. battery terminal
Make up a (fused) wire to connect from the battery to the barrel plug.
Make an earth wire and connect it to the wire GOING to the s/c clutch with the brown through it - this is the earth terminal.
Connect the live fused wire to the other (I've forgotten it's colour) terminal GOING to the s/c clutch - the clutch should now activate.
