"Start Error" in dash readout - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 12-20-2011, 05:02 PM Thread Starter
cdf912's Avatar
Date registered: Jul 2007
Vehicle: 2002 SLK, 2008 C300, 2010 ML350
Hi Guys,
so I got the dreaded "start error". Called 1-800 For Merc. He came and said battery was fine, but both my keys wont work and they don't even unlock or lock the doors. He said the fact that it says "start error" means there is nothing he could do that basically either the keys aren't talking to the car or the car isnt accepting the keys IR code. So it was towed to the dealership.
So now the dealership is saying that the tranny leak at sensor (which I have ignored for years) has leaked fluid along the wires and ended up getting fluid in some control module. They say this control module is not allowing the car to start. So they need to order one and replace it to the tune of $1000.
Well, I tend to not believe this. Car was running absolutely excellent and then just wouldn't start. Does this sound right? I saw some old posts where someone said the chrome ring around his ignition was loose, another that said the PCM module was bad. And then one post which said all I had to do was change the batteries on the key remotes and reprogram them??
Anyone have any thoughts on this? So damn frustrating to be at the dealer's mercy.
cdf912 is offline
post #2 of 8 (permalink) Old 12-20-2011, 05:25 PM
RedScorpion's Avatar
Date registered: May 2008
Vehicle: SLK 230 Kompressor 1998
Just a thought, do you have a spare key? maybe the other one will work.
RedScorpion is offline
post #3 of 8 (permalink) Old 12-20-2011, 08:36 PM Thread Starter
cdf912's Avatar
both keys don't work...but after reading about the K40 board, I'm wondering if that is the problem...
cdf912 is offline
post #4 of 8 (permalink) Old 12-21-2011, 12:23 AM
Subby_'s Avatar
Date registered: Jan 2007
Vehicle: 1998 SLK 230
Quoted: 37 Post(s)
looks like the dealer may be right... module maybe fried or the key barrel cannot energise the key to read its code to authorise the start of the car
see documents from workshop manual... drive authorisation does not touch the k40..
File Type: pdf Radio frequency DAS control module, purpose.pdf (12.5 KB, 1887 views)
- ASP pulley kit
- 87mm supercharger pulley
- Ported Eaton M62 supercharger
- Ported supercharger inlet manifold
- MAF screen & throttle body screen delete
- Automatic intercooler spray kit
- Single 2.5" Magnaflow Hi-flow cat
- Magnaflow rear muffler + Lukey Ultraflo resonator
- Shift-I progressive shift light
- Custom ECU tune
- Air box delete (custom) with BMC airfilter
- 10c degree STAR thermo fan mod
- FireStorm igntion coil booster
- 5 Bar fuel pressure regulator
Subby_ is offline
post #5 of 8 (permalink) Old 12-21-2011, 12:31 AM
Subby_'s Avatar
Quoted: 37 Post(s)
START ERROR still should not prevent you from opening and closing doors etc... looks like your keys need to be re-syncronised to the car.
to sync
- direct the remote control signal towards the receiver in the front of the interior light and press the button twice briefly.
- within 30sec place the key in the igntion and turn the key to pos 2 (dont start motor).
locking system should be now operational. remove key and check
- ASP pulley kit
- Custom ECU tune
Subby_ is offline
post #6 of 8 (permalink) Old 12-21-2011, 08:43 AM
Kobus's Avatar
Date registered: Apr 2007
Vehicle: 2001 SLK 320(203K Miles), 2002 E320 Special Edition(174K Miles)
Not going to preach to you about how stupid it is to ignore the leak for years, but although the dealer just replaces the board, many people had success by just spraying the board with MAF cleaner and then let it dry. Also need to spray the cable connectors at both ends and let the fluid drip out. You should actually drench the cable and repeat several times.
Of course if you haven't replace the connector you'll be wasting your time. The connector is less than $30 at the dealer (about $12 at Chrysler dealers) and about 15 minutes to replace.
Only two thing are infinite, the universe and human stupidity, and I'm not so sure about the former.
Albert Einstein
Honest politicians are like UFOs. Most people believe that there must be some out there somewhere, but nobody has yet been able to prove their existence.
Kobus is offline
post #7 of 8 (permalink) Old 12-21-2011, 10:57 AM Thread Starter
cdf912's Avatar
Originally Posted by Kobus View Post
Not going to preach to you about how stupid it is to ignore the leak for years,...
well I guess ya just did...and I will take my lumps..
cdf912 is offline
post #8 of 8 (permalink) Old 11-13-2013, 05:34 AM
Date registered: Nov 2013
Vehicle: 2002 SLK 200
Were you able to solve the problem? what was it?
andro333 is offline
  • Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
    W168 "Start Error" P1570 Brian Hemming W168 A-Class 12 09-01-2016 10:19 AM
    "Start Error" on Instrument Cluster Mileage Display when Cranking AC_ML W163 M-Class 9 10-06-2011 05:34 PM
    " Start Error " message - S600 1998 - help needed michobebe W140 S-Class 39 07-12-2011 02:00 PM
    C200 Kompressor Error Message on Dash: "4 FAULT" lemmyb W203 C-Class 1 04-08-2009 01:02 PM
    really need help with "start error" 1999 cl500 atlantas420 W140 S-Class 0 04-08-2008 05:21 PM
