Tunning slk 230, Pulley upgrade and etc. - Mercedes-Benz Forum
post #1 of 23 (permalink) Old 05-10-2011, 02:55 AM Thread Starter
Date registered: May 2011
Hi,
Just bought my self a Slk 230 facelift model with a 6 speed manual gearbox.
I want to upgrade the give it more HP, have a friend that works at a tunning company that told me he will do a pulley upgrade and some others mods and put the Hp up too 230 for around 1 830 dollars. Now my question is will the manual gearbox handle it or will it fail on me ?
Some say that the transmission is already at its limits and if that is true i rather not do the upgrade and just keep the car stock. Has any one done this before ?
taxas is offline
post #2 of 23 (permalink) Old 05-10-2011, 03:33 AM
Subby_'s Avatar
Date registered: Jan 2007
Vehicle: 1998 SLK 230
Quoted: 37 Post(s)
most tuning solutions were developed with the auto trans in mind as the auto transmission is very popular for MB (and only choice in most cases).
as mentioned before... stock torque is 280nM for the SLK 230. the auto trans is rated at 330nM, and the manual transmission is rated 270nM.
most pulley kits bring the torque up to around 320-330nM. so on an auto car its no problem. in a manual car you will be over the limit by nearly 20%. the torque limit is for maximum continuous torque input. its very hard to achieve continuous torque input for sustained durations on the street - different story if on the track / dyno or doing spirited driving.
SLK 230 pre and post face lift use the SG-S270/5.5 manual transmission...
question will it handle it? depends how you drive and how hard you push the car...
- ASP pulley kit
- 87mm supercharger pulley
- Ported Eaton M62 supercharger
- Ported supercharger inlet manifold
- MAF screen & throttle body screen delete
- Automatic intercooler spray kit
- Single 2.5" Magnaflow Hi-flow cat
- Magnaflow rear muffler + Lukey Ultraflo resonator
- Shift-I progressive shift light
- Custom ECU tune
- Air box delete (custom) with BMC airfilter
- 10c degree STAR thermo fan mod
- FireStorm igntion coil booster
- 5 Bar fuel pressure regulator
Subby_ is offline
post #3 of 23 (permalink) Old 05-10-2011, 03:51 AM Thread Starter
Im gonna ask the tunning company where my friend works about this, but it sounds strange the they put a manual that almost cant handle the the stock.
Edit: got a reply back from the Tunning company, they say that the 6 Speed manual can handle the upgrade no problem and that its well over specs when regarding stock.
Im lost now
taxas is offline
post #4 of 23 (permalink) Old 05-10-2011, 04:09 AM
Subby_'s Avatar
Quoted: 37 Post(s)
more from WIS
ID:	374476   Click image for larger version
- ASP pulley kit
- Custom ECU tune
Subby_ is offline
post #5 of 23 (permalink) Old 05-10-2011, 04:34 AM Thread Starter
Okey, but still why did Mb put a transmission that handels 270 nm as max when the engine produces 280nm.?
Edit: Subby sorry to bother you mate but can you check the 320 manual specs and post them for me please ?
taxas is offline
post #6 of 23 (permalink) Old 05-10-2011, 04:56 AM
Subby_'s Avatar
Quoted: 37 Post(s)
they do it so you cant modify your car... why do you think the newer post face lift slk has a SMALLER supercharger (M45) than the older SLK? they quickly found doing a bit of work for little money you can make way more power than the next car up the SLK320...
WIS says the SLK320 has a SG-S400/5.3 manual transmission (rated for 400nM). the 270nM looks like the best match for the SLK230 and its only 4% off...
edit: for your info the SLK32 the top of the range SLK auto trans is rated maximum of 580nM
- ASP pulley kit
- Custom ECU tune
Subby_ is offline
post #7 of 23 (permalink) Old 05-10-2011, 05:02 AM Thread Starter
as it is now i don't think i will tune the car, will wait until some one with a manual gearbox has replied on the thread.
taxas is offline
post #8 of 23 (permalink) Old 05-10-2011, 06:52 AM
Date registered: Apr 2008
Vehicle: '00 slk230k (engine swap), '75 300D, 2011 GTI
I've got the 5spd gear box.. i tear it up everyday of driving. I've done the ASP pulley, exhaust work, injector work, intake/intercooler work, larger FPR, few other things
been tearing it up since 2008
mind you... Once I get turbo stuff done, I will obviously run the 5spd for a while.. but I may have to switch to a getrag tranny or somethin. I'll see when I get there
SLK230
...modified...
properimage.net
gakz is offline
post #9 of 23 (permalink) Old 05-10-2011, 02:26 PM Thread Starter
How many Hp do you have? and did you do anything to the clutch or gearbox ?
Also subby can you please post the 5 speed manual specs as well ?
Thank you all for the info you provided and time you spent helping me out by answering my stupid questions :P
taxas is offline
post #10 of 23 (permalink) Old 05-10-2011, 04:03 PM
Subby_'s Avatar
Quoted: 37 Post(s)
dont have WIS on this computer to check have to do it later but id imagine it to be roughly the same.
the 5sp manual i belive is only for the older SLK?
- ASP pulley kit
- Custom ECU tune
Subby_ is offline
Help!!! 230 SLK Pulley Upgrade Required Abacus R170 SLK-Class 10 10-16-2006 06:55 AM
Which Pulley Kit SLK 230?? emrvr R170 SLK-Class 4 10-16-2006 06:52 AM
I wish to upgrade my SLK 230 Kompressor with a pulley + ECU kit....does it worth or not? Gheorghe R170 SLK-Class 16 04-26-2003 12:00 AM
Pulley kits on SLK 230 LotusFan R170 SLK-Class 5 11-18-2002 03:22 PM
Any experience with KLEEMANN pulley upgrade for 230? gab R170 SLK-Class 0 01-17-2002 06:27 PM
