HOW TO Remove ENTIRE Headlight Assembly '99 SLK - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 05-06-2011, 04:53 PM Thread Starter
Date registered: May 2011
Vehicle: 1999SLK230
Alright, after hours and hours of searching online, I have found many dozen threads of people replacing the standard headlight unit with a projector with halo type... However, the one step that is absolutely destroying my life is the back lower third nut to remove the original light assembly. It is never mentioned on several detailed step by step write ups... It's blown over with "just remove the light assembly". I did find one thread that mentioned that you do not have to remove the bumper. I've looked deep inside with a mirror and you could not get it from underneath anyhow. ???
Does anyone know the secret to getting to that back lower 3rd bolt?
richferguson is offline
post #2 of 4 (permalink) Old 05-06-2011, 05:12 PM
leapyfish's Avatar
Date registered: Apr 2008
Vehicle: 1998 SLK230 210,xxx Miles
Quoted: 5 Post(s)
leapyfish is offline
post #3 of 4 (permalink) Old 05-06-2011, 07:36 PM Thread Starter
Vehicle: 1999SLK230
Owner Manual!
Originally Posted by leapyfish View Post
You remove the turn signal Turn Signal
that allows you to get to the 3rd bolt
Its also in the owners manual.
A million thanks... I'll look into that tomorrow and see if it works... I would have never thought to look up something this specific in the owners manual. I'm so grateful for this to save a lot of mechanics time and expense of install.
post #4 of 4 (permalink) Old 05-06-2011, 08:40 PM Thread Starter
Vehicle: 1999SLK230
WOW. SIMPLE
No wonder nobody mentioned it... it's SO simple once you KNOW the secret tab to press between the lights. Thanks again. All wired up in just minutes.
    how do you remove entire positive battery cable huskerto W163 M-Class 5 10-31-2014 07:48 PM
    WTB 94-95 Entire grille assembly OEM only semis1 W124 E,CE,D,TD Class 0 03-23-2011 10:24 AM
    Help! Bought an '08 E63 w/ hail damage. Pano roof out. Replace entire assembly??? Rebuilt_E63_Hail W211 E55 AMG, E63 AMG 8 01-12-2011 05:55 PM
    Anybody ever remove an entire door? guarddog W126 S,SE,SEC,SEL,SD,SDL Class 7 07-06-2008 08:46 PM
    HELP - need help to remove headlight assembly 124via126 W126 S,SE,SEC,SEL,SD,SDL Class 5 05-21-2008 05:47 PM
