Key fob wont work!! - Mercedes-Benz Forum
post #1 of 13 (permalink) Old 03-10-2011, 07:49 PM Thread Starter
tosha.3's Avatar
Date registered: Apr 2006
Vehicle: 1998 Mercedes SLK 230 kompressor
Question Key fob wont work!!
Stopped working 3 days ago. Bought it 5 years ago from MB. Replaced batteries-no result. Tried it at Autozone on their keyfob stand-not working, but light in my keyfob still lights up. Something wrong with signal of key fob or car receiver. Is there is a fuse in the car for receiver? Any help will be greatly appreciated.
Attack life! It's going to kill you anyway.
'01 Suzuki Hayabusa
tosha.3 is offline
post #2 of 13 (permalink) Old 03-10-2011, 08:19 PM
Date registered: May 2008
Vehicle: 2002 SLK 230. ASP pulley, HID 4300k Projectors, Smoked LED tails, Bipes bvrc
Quoted: 2 Post(s)
Did you try it with another key fob?
Mantist is offline
post #3 of 13 (permalink) Old 03-10-2011, 08:58 PM Thread Starter
tosha.3's Avatar
I have only one fob
'01 Suzuki Hayabusa
tosha.3 is offline
post #4 of 13 (permalink) Old 03-10-2011, 10:35 PM
Subby_'s Avatar
Date registered: Jan 2007
Vehicle: 1998 SLK 230
Quoted: 37 Post(s)
might just have to resyncronise the key fob to the car. check owners manual or search on here... not too hard to do
- ASP pulley kit
- 87mm supercharger pulley
- Ported Eaton M62 supercharger
- Ported supercharger inlet manifold
- MAF screen & throttle body screen delete
- Automatic intercooler spray kit
- Single 2.5" Magnaflow Hi-flow cat
- Magnaflow rear muffler + Lukey Ultraflo resonator
- Shift-I progressive shift light
- Custom ECU tune
- Air box delete (custom) with BMC airfilter
- 10c degree STAR thermo fan mod
- FireStorm igntion coil booster
- 5 Bar fuel pressure regulator
Subby_ is offline
post #5 of 13 (permalink) Old 03-12-2011, 10:16 PM Thread Starter
tosha.3's Avatar
re-sync doesnot work
'01 Suzuki Hayabusa
tosha.3 is offline
post #6 of 13 (permalink) Old 03-18-2011, 03:44 PM
Date registered: Jan 2010
Heck, my light doesn't work, which means nothing works. I'm back to 1965 putting the key in the door. Thought about getting a new one on the bay, but thought better to not waste my $$$.
Harleyman14 is offline
post #7 of 13 (permalink) Old 03-19-2011, 02:19 AM
Billy22Bob's Avatar
Date registered: Dec 2010
Vehicle: Australia, 99SLK230 R170, 2001SLK32
Quoted: 15 Post(s)
does your central locking work from the console?
Does your courtesy light dim when you get in the car or when you open the car door to get out?
If not - then you may have a PSE issue?
If you dont know about the PSE - then that heightens the fact that it might be an issue, given it's probably wet.
Car been out in the rain recently?
Billy22Bob is offline
post #8 of 13 (permalink) Old 03-19-2011, 12:50 PM
Central locking is working.
Courtesy light dims but only turning itself off.
I know nothing about the PSE. What and where is it. Yes I have driven thru melting snow and washed it, so its been around water.
However the light in the key fob never comes on, even when replacing the battery, that's why I think it's dead.
post #9 of 13 (permalink) Old 03-19-2011, 12:56 PM
Date registered: Oct 2005
Vehicle: 1999 SLK230 2009 E350
Quoted: 2 Post(s)
Unfortunately it sounds like the key fob transmitter is no longer working which means replacing it. Even if the PSE was dead, which yours isn't, the car lights should flash when the signal from the key fob is received. Since resync didn't work and batteries have been replaced (your sure their good and in correctly), there isn't much left except the fob itself.
upstate engineer is offline
post #10 of 13 (permalink) Old 03-19-2011, 01:13 PM
I see them on -bay and other areas. My fob is a 2 button w/panic, could I sincro a 3 w/panic to the car using manual instructions or do I have to stay wiht the 2-panic?
    Key Fob wont turn HELP! tmurtaza For Sale/Wanted/Trade/Giveaway 2 01-21-2011 02:13 PM
    ignition key wont work!!!! james wilson W202 C-Class 6 07-10-2010 10:27 PM
    KEY FOB WONT WORK!! 1999 E300 Turbodiesel W210 E-Class 3 07-10-2010 10:55 AM
    car wont start-flat key fob?? zeff737 C208/A208 CLK-Class 0 04-14-2010 11:03 AM
    my battery died now my key wont work billc4502 W203 C-Class 1 12-03-2006 09:07 AM
