coolant change SLK230 - drain radiator & engine block - Mercedes-Benz Forum
post #1 of 10 (permalink) Old 02-04-2011, 09:46 PM Thread Starter
Subby_'s Avatar
Date registered: Jan 2007
Vehicle: 1998 SLK 230
Quoted: 37 Post(s)
took some pics to show people who are not sure where the drain points are of the slk230. i dont think anyone here actualy drains the engine block - a fair bit of coolant is in there... if your under the car you might as well.
first pic is the radiator drain point fairly easy to find and easy to get too... now to the engine block drain point. this is located on the side with the exhaust manifold look up where the steering is and you will see the nipple.
now i dont know how WIS recons you can use a box wrench in there but theres hardly any room and im paranoid stripping the bolt. i used a 19mm socket + universal joint extension on a ratchet. go nice and slow as coolant will drip and then gush out - highly recommended you do this when the car/coolant is cold for safety.
if you have your car on jack stands, jack up both front and rear to keep it level when draining.
you can flush the system with clean water until clean water comes out of the drain points. close them up and fill system with 50/50 anti freeze & water mix. use only MB anti freeze or valvoline/zerex g0-5
ID:	355310   Click image for larger version
ID:	355311   Click image for larger version
netdvn and josephshark like this.
- ASP pulley kit
- 87mm supercharger pulley
- Ported Eaton M62 supercharger
- Ported supercharger inlet manifold
- MAF screen & throttle body screen delete
- Automatic intercooler spray kit
- Single 2.5" Magnaflow Hi-flow cat
- Magnaflow rear muffler + Lukey Ultraflo resonator
- Shift-I progressive shift light
- Custom ECU tune
- Air box delete (custom) with BMC airfilter
- 10c degree STAR thermo fan mod
- FireStorm igntion coil booster
- 5 Bar fuel pressure regulator
Subby_ is offline
post #2 of 10 (permalink) Old 02-05-2011, 12:07 PM
oberoi's Avatar
Date registered: Mar 2006
Vehicle: 2010 C200 CGI /W203/SLK230/W202/230E/280SE
Quoted: 33 Post(s)
Tried the drain on the block first time and it was so stiff that I gave it away and resolved just to take extra care when flushing
Oberoi
oberoi is offline
post #3 of 10 (permalink) Old 02-05-2011, 02:19 PM
Date registered: Sep 2008
Vehicle: 2003 SLK230 USA model, Auto Transmission, Stock, Firemist Red
Quoted: 26 Post(s)
Excellent write-up with instructional pictures. I have used engine drain plugs especially when pulling the head(s).
The way I do a coolant changes is:
Drain cold coolant through radiator drain plug.
Fill coolant system with garden hose water several times as water drains out.
Start engine with heater on, then keep garden hose running through coolant filler cap hole for a couple of minutes.
When coolant drains as clear water, turn off engine.
After total drain, install radiator drain plug/cock.
Fill with a couple of gallons or so of distilled water.
Run engine for a few minutes.
Drain distilled water from radiator drain cock.
Install drain plug.
Fill 50 % of system with appropriate radiator fluid.
Top off with distilled water.
Thom
Automatic Transmission
No Alterations/Stock
Southeast, USA
DecoThom is offline
post #4 of 10 (permalink) Old 02-05-2011, 07:49 PM
Kobus's Avatar
Date registered: Apr 2007
Vehicle: 2001 SLK 320(203K Miles), 2002 E320 Special Edition(174K Miles)
I always do this with the engine warm so that the thermostat is also open for better drainage. Also ensure that the heater control are set to maximum temperature so that the duo valves are open for draining from the heater core. Now I do have a different engine (320) and on mine I can remove the drain plug and no water will flow out as long as I keep the cap on the overflow bottle screwed on. I then position my container, open the cap on the overflow tank and get a fast outflow. To ensure the overflow container empty completely, I blow into the tank.
Also, I park with the rear slightly higher than the front, maybe 1 to 2 inches. On my last coolant change, I measure the amount drained at 10 quarts - out of a system total of 11 quarts. For that reason I did not bother with the drain-cocks on the engine, but just filled it with distilled water, warmed it up, drained and repeated.
Also, remember to re-check the coolant level over the days following. It takes a couple of days to get all the air out of the system. Remember to use the heater so that any air there is forced out as well.
Only two thing are infinite, the universe and human stupidity, and I'm not so sure about the former.
Albert Einstein
Honest politicians are like UFOs. Most people believe that there must be some out there somewhere, but nobody has yet been able to prove their existence.
Kobus is offline
post #5 of 10 (permalink) Old 02-12-2011, 01:03 AM Thread Starter
Subby_'s Avatar
Quoted: 37 Post(s)
here is an article about mb coolant... interesting read.
- ASP pulley kit
- Custom ECU tune
Subby_ is offline
post #6 of 10 (permalink) Old 07-26-2011, 07:15 AM
Date registered: Apr 2008
Vehicle: '00 slk230k (engine swap), '75 300D, 2011 GTI
bump.. ill be swappin my radiator out when i return. Helpful post.
I suppose ill just be draining the radiator, then ill be removing it and the fan to swap
SLK230
...modified...
properimage.net
gakz is offline
post #7 of 10 (permalink) Old 11-09-2014, 11:22 AM
Date registered: Apr 2009
Vehicle: 2007 E350 Previous: '05 CLK 320 (rear-ended/totaled), '98 E 300TD (Sold at 250k mi)
Quoted: 5 Post(s)
Thanks a lot for that info. Nice to see at the end that I haven't been as much of a dick to my car as I imagined, since Mercedes doesn't tell you to replace coolant until 15 years/150k miles. I'm just coming up on 10 yrs/142k.
Since I run perfectly well-cooled and with no problems, maybe the smart thing to do is to stick with the MB antifreeze.
HoldenBeachBum is offline
post #8 of 10 (permalink) Old 11-09-2014, 03:26 PM
Date registered: Jan 2004
Quoted: 30 Post(s)
The 15 year/150,000 mile interval didn't appear until about the 2003 model year and it is pretty clearly pointed out in the owners manual books. Not sure if they have stuck with that. If you want to do a repeat of that interval, then you will need to replace the chemical pack. I'm not even sure where it is located or if it is even replaceable. If you don't replace it, then you will be back to an every three year interval. In any case the Mercedes coolant or Zerex GO5 would be good choices.
Len
'59 220S Cabriolet - for sale - http://www.mbzponton.org/mbz220s/sellswap/car4sale.htm
'83 240D original owner 351,500 miles - sadly I let it go
'88 560SL 41,000 miles being parted out - https://sites.google.com/site/mercedesstuff/home
'99 E300 turbo 207,000 miles
'03 SLK320 37,500 miles
'14 Smart electric 9700 miles
sokoloff is offline
post #9 of 10 (permalink) Old 11-10-2014, 05:52 PM Thread Starter
Subby_'s Avatar
Quoted: 37 Post(s)
the chemical pack is in the plastic expansion tank where the radiator cap screws onto (non user serviceable.). you would need to replace the expansion tank at the correct interval so the chemical pack doesnt completely deplete.
like i said the coolant in conjunction WITH the chemical pack (in the expansion tank) will give it the long life. from what i see doent apply to the R170 only newer benzs...
- ASP pulley kit
- Custom ECU tune
Subby_ is offline
post #10 of 10 (permalink) Old 11-13-2014, 10:36 AM
Quoted: 30 Post(s)
My 2003 170 has the fifteen year coolant. I think that might have been the first year?
Len
sokoloff is offline
    coolant drain plug on the engine block p100 W123 E,CE,D,CD,TD,TE Class 8 02-16-2014 03:18 AM
    radiator, engine block drain pictures? sclass200812 W140 S-Class 1 08-19-2010 02:18 PM
    Engine Block Coolant Drain Plug valleydog R170 SLK-Class 8 03-29-2010 09:10 AM
    What size hex for coolant block drain plug and freeze plug for engine block heater? hheynow W123 E,CE,D,CD,TD,TE Class 11 09-15-2008 05:16 PM
    Engine Block Coolant Drain Location? Vincent W126 S,SE,SEC,SEL,SD,SDL Class 2 01-09-2004 08:12 PM
