Safe way to carry LP tank - Mercedes-Benz Forum
post #1 of 9 (permalink) Old 03-03-2010, 12:54 AM Thread Starter
vfhondas's Avatar
Date registered: Apr 2009
Vehicle: 2000 SLK 230
I use my SLK as a daily driver and when it came time to get a propane tank exchanged, I needed a way to secure it. Those things are too dangerous to just let roll around in the trunk. Who wants their trunk trashed by a rouge tank ?
It was very easy to build and can but done with at least 1/2" plywood or MDF and some 2"x4" blocks
Tank is very stable and you can still do some "spirited driving" and put the top down.
ID:	293982   Click image for larger version
ID:	293983   Click image for larger version
ID:	293984   Click image for larger version
vfhondas is offline
post #2 of 9 (permalink) Old 03-03-2010, 01:23 AM
delhiboy3732's Avatar
Date registered: Jan 2008
Vehicle: SLK32
Send a message via Yahoo to delhiboy3732
Speechless.
delhiboy3732 is offline
post #3 of 9 (permalink) Old 03-03-2010, 02:59 AM
MFG1's Avatar
Date registered: May 2009
Vehicle: 2003 c230 coupe
it should always be valve pointing up though, but the effort is certainly there
MFG1 is offline
post #4 of 9 (permalink) Old 03-03-2010, 03:03 AM Thread Starter
vfhondas's Avatar
Valve up...top up
Valve down....TOP DOWN !!!
vfhondas is offline
post #5 of 9 (permalink) Old 03-03-2010, 03:58 PM
oberoi's Avatar
Date registered: Mar 2006
Vehicle: 2010 C200 CGI /W203/SLK230/W202/230E/280SE
Quoted: 33 Post(s)
Had to carry one the other day also and felt distinctly unsafe in case the refill guy forgot to tighten something - put the top down anyway
Had a case some years ago of turning the main tap off after use and it kept turning - the whole assembly came out (LH thread) with a shreiking sound you wouldn't believe - it was a full tank and luckily was on an outside balcony - scared the hell out of me - bad design
BTW - has that tank reached the end of its useful life? - Here it is illegal to refill or sell a tank over 10 yrs old
Oberoi
oberoi is offline
post #6 of 9 (permalink) Old 03-03-2010, 04:15 PM
danger450's Avatar
Date registered: Jan 2007
Vehicle: R230 SL500 BRILLIANT SILVER METALLIC
Quoted: 5 Post(s)
Send a message via AIM to danger450 Send a message via Yahoo to danger450
Just another reason to keep the SLK as my daily driver ...
UNBELIEVEABLE Trunk Space ! Ha Ha, try that in a Solstice !
AND putting the top down, awesome ! Thanks for the TIP !
2003 SL500 "AMG SPORT" Brilliant Silver Met.
181,000 MILES STRONG!
OPTIONS: SL1, SL2, SL3, 051, 889
MODS: 2009 AMG E63 rims, 2012-Style Arrow LED mirror covers
(with LED ground, courtesy light wired to the dome light), tint,
LED projector city lights, clear lenses, Amber-chrome blinker bulbs,
clear third brake light.
Stay on top of your ABC Maintenance! It is NOT in A or B Flex Service's!
Change FLUID AND FILTER at least every 40,000 miles!
danger450 is offline
post #7 of 9 (permalink) Old 03-05-2010, 05:27 AM
Date registered: Sep 2003
Vehicle: 1999 SLK230
LP Tank
I also use my 99 230SLK as a daily driver and I transport LP tanks in it. I find that standing the tank up in the passenger's footwell with the seat way back works well. I place a rag between the tank and the glove box door and have never had a problem with damage. I always put a window down or the top down when I carry a LP tank.
steves is offline
post #8 of 9 (permalink) Old 03-05-2010, 06:23 AM
Vehicle: SLK32
Good point.
post #9 of 9 (permalink) Old 03-05-2010, 06:42 AM Thread Starter
vfhondas's Avatar
Well if that works for you, thats great. But I find that the interior finish is way too fragile and a rag would not stop the damage if tank started to move.
I always need to be prepared for the worst case scenerio because of the large majority of very bad drivers here. It's not uncommon here for a taxi to slam on the brakes and make a u-turn right in front of you, just to pick up a fare.
I need my tank secured.
vfhondas is offline
"Safe schools czar" not so safe after all mlfun Off-Topic 4 10-03-2009 05:30 PM
How many of you carry concealed???? ZYALATR C208/A208 CLK-Class 22 11-20-2007 07:44 PM
What do you carry in your trunk? Nascar Fan R/C107 SL/SLC Class 30 06-08-2007 02:22 AM
Was something loose? I filled my gas tank, and my fuel meter never reset to the full tank reading.. AC_ML W163 M-Class 5 08-20-2004 07:12 AM
On the good side.. I am getting actual 330 m/tank city and 400 m/tank highway AC_ML W163 M-Class 13 09-10-2003 11:43 AM
