Hi all,
I'm back again, me and my "weird" 2.0L kompressor engine from Greece. After some aesthetic changes i've made on the car it's about time to do something about the horsepower. I've searched a lot about the pulley upgrade and found out that the best option is ASP or Vortech (don't know if further mods need to be done in this case).
And now the BIG question: Has anyone ever consider putting an adjustable Bypass valve in the car to decrease the leak of compressed air? I'm asking this because i measured the the pressure with the leaking hole tapped and the gauge was about to climb over 1 bar (14psi) and then stopped cause i feared that something bad would happen. So, why should we change pulley and overheat the supercharger and not just swap bypass valves?
The supercharger itself creates more pressure than we need and use...
Just a thought....i'm waiting some replies because i think thats something interesting.
P.S. I forgot to mention that i have the pre-facelift Slk 99' with Eaton M62, 2.0L engine and 193 Hp.
