Help with Spray Nozzle in Windshield Washer System 1999 SLK 230 - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 01-08-2010, 11:03 AM Thread Starter
dbottoms's Avatar
Date registered: Sep 2002
Hello SLK'ers,
I need some Help with one of my Spray Nozzles in my 1999 SLK230 Windshield Washer System.
The spray on the driver's side, left nozzle (seated in the driver's seat) has slowed to a trickle. An extremely tiny amount of fluid seeps out when I press the washer button. The other 3 nozzles continue to operate very effectively. I am not very mechanically minded, but, as far as I can tell the nozzle tip is clear of debris. And I'm moderately confident the hose isn't frozen because the 3 of the 4 Nozzles work fine. We're enjoying 15F temps in the Midwest with our first 5+ inch snow storm, and driving with the road salt and snow soot can be a challenge with this nozzle not working.
Does anyone have any recommendations? Any guides which shows what I might check?
Kindly yours,
Douglas
1999 SLK 230, Sport Pkg, Auto, Special Order Obsidian Black Metallic, Oyster leather, First met on August 20, 1999
<IMG src=http://home.comcast.net/~dbottoms/douglasslk2.jpg>
dbottoms is offline
post #2 of 5 (permalink) Old 01-10-2010, 11:58 PM
AntoN C.'s Avatar
Vehicle: E430, W210, stock
Originally Posted by dbottoms View Post
Hello SLK'ers,
Kindly yours,
Douglas
Hi, i also have a same problem but dont know what could cause this
AntoN C. is offline
post #3 of 5 (permalink) Old 01-11-2010, 04:31 AM
Jeff Kushner's Avatar
Date registered: Feb 2006
Vehicle: 2002 SLK230
I can only relate to you what I did to my car. When i bought my 02, the passenger side washer was coming out in a trickle....I simply used a very small needle and worked it into the hole very carefully....perfect! It worked like new after that....it's not rocket science, just a piece of crud blocking it.
jeff
Jeff Kushner is offline
post #4 of 5 (permalink) Old 01-11-2010, 12:29 PM
isarescu's Avatar
Date registered: Jan 2008
Vehicle: SLK 230 Kompressor, 2001
I had the same problem. I solved it as Jeff did.
isarescu is offline
post #5 of 5 (permalink) Old 01-11-2010, 02:00 PM
delhiboy3732's Avatar
Vehicle: SLK32
Send a message via Yahoo to delhiboy3732
I did too.
delhiboy3732 is offline
    Windshield Washer nozzle pattern needed bayhas W140 S-Class 14 03-17-2009 12:10 PM
    FOG LIGHTS and WINDSHIELD WASHER NOZZLE tuan0648 R170 SLK-Class 1 08-02-2008 02:54 PM
    How to remove windshield washer nozzle? kjhC320 W203 C-Class 0 06-05-2007 07:57 PM
    Removing washer fluid spray nozzle skim7372 W210 E-Class 3 02-07-2007 08:44 PM
    how to open winshield washer spray nozzle? C R170 SLK-Class 11 03-21-2005 01:55 PM
