SLK230 Brake light Failure - Mercedes-Benz Forum
post #1 of 13 (permalink) Old 06-29-2009, 07:42 PM Thread Starter
Date registered: Jun 2009
Vehicle: 2001 SLK 230 leather Anthracite, Magma Red ;)
Hey all,
I have a 2001 SLK 230 and have a failed left side brake light and corresponding fault light on the dash.
FIXED THANKS ALL!
Slick SLK is offline
post #2 of 13 (permalink) Old 06-29-2009, 08:57 PM
Chris A's Avatar
Date registered: Jun 2006
Vehicle: 2001 SLK 320
Have you had the recall tail light assy replaced? See sticky thread at top.
Women can fake orgasms. . . . men can fake whole relationships.
Chris A is offline
post #3 of 13 (permalink) Old 06-29-2009, 09:02 PM Thread Starter
I read through that sticky, I dont think it applies to Australian delivered cars, certainly I have not heard of this recall from Mercedes.
Regardless though the taillight assembly seems to be functioning fine, I think the fault is in the wiring not the tail light itself.
post #4 of 13 (permalink) Old 06-30-2009, 03:29 AM
Date registered: Oct 2007
Vehicle: 2002 SLK 230 1986 560SL 2008 Honda CRV
Have a look at your license plate light that bulb may be out.
livefreeordie is offline
post #5 of 13 (permalink) Old 06-30-2009, 06:07 AM
Bruce R.'s Avatar
Vehicle: 2002 SLK 32 AMG, bone stock. 1987 190E 2.3-16 valve (destroyed). 2005 E320 new toy.
Quoted: 41 Post(s)
That's the problem, they all LOOKED like they were OK, when in fact they were not.
The primary problem was with the contact points in the sockets, try replacing them with the newer black sockets as opposed to the old blue-green ones. Clean off the circuit strips with a pencil eraser first then add some transister heat transfer grease before you put the new socket in place.
that should help.
"Negotiating with Obama is like playing chess with a pigeon, the pigeon knocks over all the pieces, on the board and then struts around like it won the game."
Vladimir Putin
"They have gun control in Cuba. They have universal health care in Cuba. So why do they want to come here?"
Paul Harvey 8/31/94
"The only people who have quick answers don't have the responsibility of making the decisions."
Justice Clarence Thomas
Bruce R. is offline
post #6 of 13 (permalink) Old 06-30-2009, 07:19 AM
oztds's Avatar
Date registered: Oct 2006
Vehicle: Two 1998 SLK230s, 2003 SLK230 SE, 2002 ML320
Recall doesn't apply in Oz
Bruce is correct - the problem is pitting in the contact rails and socket contacts and gives intermittent stop light operation. The dash light comes on and stays on if the stop light is even momentarily out of action.
The problem... http://www.benzworld.org/forums/2877786-post194.html
I have tried several solutions.
1. Initial solution - Mercedes SLK230 Stop Lights
2. Similar http://www.benzworld.org/forums/2002150-post5.html
3. Another http://www.benzworld.org/forums/r170...-long-8-a.html
4. DIY socket rewire http://www.benzworld.org/forums/2017732-post69.html
5. Use a Narva socket and wire to the power rails http://www.benzworld.org/forums/2580666-post4.html
6. I ultimately replaced the tail light assemblies with the LED ones from Taiwan - no problems since.
http://www.benzworld.org/forums/r170...ights-yet.html
My modded Merc tail light assemblies and OEM headlights live in boxes in the garage and I use Chinese lanterns.
PS. Put details of your SLK model and location on your avatar on the left so we knwo how best to identify the variant of SLK to respond to questions.
“The difference between genius and idiocy? Genius has its limits." - TWS
oztds is offline
post #7 of 13 (permalink) Old 06-30-2009, 03:28 PM Thread Starter
I'll have a play with some of the solutions you good folks posted.
What concerns me though is that there is not even 12 volts coming from the harness to the left hand tail light itself when the brake is applied. There is on the right side.
I think it will require a trip to Mercedes, beauty of it now is that if they tell me the tail light assembly is faulty and needs replacing, I have some options to modify courtesy of this site and oztds. Thanks guys!
post #8 of 13 (permalink) Old 06-30-2009, 06:59 PM Thread Starter
Ok one more thought then....
If the ecu has detected a fault with the left hand brake light, does it stop the signal (voltage) going to that light until the ecu is reset (say at the dealer)? This in my mind at least would explain why the light is not working at all and there is no voltage to the light at all.
its just a bit strange, the car has only done 15000 km's so I would assume the pitting or damage to the circuit in the tail light would take some time to occur?
post #9 of 13 (permalink) Old 06-30-2009, 07:12 PM
Chris A's Avatar
Sorry didnt see where you are located. Brake lights are often on a common circuit. If you have power to your right stop light you should have power to your left and center. A short would blow a fuse so that leaves you with a bad wire to the bulb or bad tail light assy. I have never followed the wires though in this car but I have in others. The ECU Im sure has nothing to do with that as my bulb out light came on once a week until i got my tail lights replaced. never had to reset it just jiggle the bulb.
Chris A is offline
post #10 of 13 (permalink) Old 06-30-2009, 08:46 PM Thread Starter
All sorted
Ok guys ignore my dribble.
I was looking at the wrong bulb / connector
Yes its the bulb holder, its been shorting
Fixed based on the pics in the link oztds provided.
Thanks again and sorry to be confusing.
Question is why MB Australia is not recalling these
Brake light out, '98 SLK230 jdrocci R170 SLK-Class 11 11-02-2008 08:59 AM
2001 C240 Brake light failure leading to ESP/BAS Failure lxshk Audio & Telematics Forum 1 08-04-2008 09:54 PM
Brake failure Light when trying to reverse gear with brake pedal uylee W204 C-Class 1 12-06-2007 11:18 AM
brake light failure on 03 SLK 32 adrose R170 SLK-Class 0 10-10-2006 08:03 PM
Brake light failure drapclan R/C107 SL/SLC Class 2 09-07-2005 07:29 PM
