Rear Differential: What size Allen wrench? - Mercedes-Benz Forum
post #1 of 9 (permalink) Old 04-10-2009, 12:56 PM Thread Starter
Date registered: Mar 2008
Draining and replacing the rear differential lube. What size Allen wrench is required back there? I don't have any that fit.
SteveMras is offline
post #2 of 9 (permalink) Old 04-10-2009, 01:47 PM
32krazy!'s Avatar
Date registered: Oct 2008
Vehicle: PROUD OWNER! 2002 slk32 AMG
14mm hex. i found a set at harbor freight for 15$ its in socket form and you may need a 3/8 drive breaker to get the plugs out. i just did mine refilled with 44 ozs of mobil 1 synthetic lube. you will also need the small pump to refill the rear diff. no room to tip bottle. theres a tech on this very helpful
32krazy! is offline
post #3 of 9 (permalink) Old 04-10-2009, 06:23 PM
delhiboy3732's Avatar
Date registered: Jan 2008
Vehicle: SLK32
Send a message via Yahoo to delhiboy3732
I also bought it from Harbor Freight. The rear is not much of an issue. however, the real issue is with the transmission bolts as it uses the same 14mm hex however there is not much space. They sell 14mm Hex key for like $6 which is very useful and you can for sure open up the transmission also with it.
delhiboy3732 is offline
post #4 of 9 (permalink) Old 04-10-2009, 07:27 PM
32krazy!'s Avatar
i guess you mean to remove the tranny from the engine? i think that may be beyond my abilities!
im also a bit of a tool slut! i cant help collecting new tools for my box!
32krazy! is offline
post #5 of 9 (permalink) Old 04-10-2009, 08:58 PM
Date registered: Sep 2008
Vehicle: 2003 SLK230 USA model, Auto Transmission, Stock, Firemist Red
Quoted: 26 Post(s)
3/8th", 1/4" drive, etc. allen and torx wrenches are far superior to old L shaped wrenches. You can get much better torque with the ratchet wrenches. Advance Auto has some decent sets usually with 3/8th" drives.
Thom
Automatic Transmission
No Alterations/Stock
Southeast, USA
DecoThom is offline
post #6 of 9 (permalink) Old 04-10-2009, 11:07 PM
Vehicle: SLK32
No, I meant to remove the bolts to drain and refill the transmission oil. Only the above mentioned tool worked for for the 230. Of course, you have a different car so it might not apply to you.
post #7 of 9 (permalink) Old 04-11-2009, 06:00 AM
32krazy!'s Avatar
definately different. my tranny bolts and drain plug were a small torx t27
32krazy! is offline
post #8 of 9 (permalink) Old 04-11-2009, 11:20 AM
MadHungarian's Avatar
Date registered: Jun 2008
Vehicle: 1999 SLK 230
So I guess my question is, is the transmission drain plug (size) on the manual different from the plug on the auto? Ditto the 230, 320, and 32? I presume the differential plugs are all the same?
MadHungarian is offline
post #9 of 9 (permalink) Old 04-11-2009, 11:24 AM
32krazy!'s Avatar
cant say for the others but my 32 is an auto and needed a small metric allen for the drain plug. the bolts that hold the tranny pan were a small t27 torx
32krazy! is offline
    Differential Bushing (rear) Hex Bit size? springsman W124 E,CE,D,TD Class 3 05-30-2007 09:51 AM
    Wrench size for differential plug dentate gyrus W123 E,CE,D,CD,TD,TE Class 7 04-01-2007 12:44 AM
    Help! How do u remove a 99 exhaust tip? D Allen wrench nut is stuck. Can it be loosen? DLeconte R170 SLK-Class 4 03-06-2002 07:15 AM
    Q. What size allen wrench to replace front brake pads? darren R170 SLK-Class 6 09-09-2001 03:01 PM
    Metric Allen Wrench for Manual Transmission and Differential Oil Check Guest (MBNZ) W123 E,CE,D,CD,TD,TE Class 1 09-04-2001 07:48 AM
