Fuel Tank Filling Problem SLK320 Pump keeps shutting off - Page 2 - Mercedes-Benz Forum
post #11 of 17 (permalink) Old 05-03-2009, 05:55 PM Thread Starter
hilarushi's Avatar
Date registered: Jan 2007
Vehicle: W210, W211, W163
Quoted: 5 Post(s)
Post Update. Problem fixed.
Just wanted to update on this issue.
It seemed that the charcoal canister (ventilation) was not the problem in my case.
The problem was with the FUEL FILLER TUBE CHECK VALVE shown as number 4 in the diagram that I have posted above. I got a wire and started pushing it in through the filler tube. At first it got stuck and after several tries it was able to go through and unstuck the valve.
So if it is impossible for you to fill your fuel tank this could be your problem. Impossible I mean when the fuel pump at the gas station keeps shutting of every two seconds even at the slowest gas flow from the fuel pump.
Thank you all for you suggestions and replies above.
hilarushi is offline
post #12 of 17 (permalink) Old 05-03-2009, 06:55 PM
zft325's Avatar
Date registered: Mar 2007
Vehicle: 08 ml320 cdi,slk 230,01 boxster S,04 carrera911, 99 S320,67 GT350mustang,02G500L,96 s600 w140
Quoted: 47 Post(s)
Send a message via Yahoo to zft325
thanks for enlightening us on this matter.
EVERY PROBLEM CAN BE FIXED WITH A LIL BIT OF PATIENCE
zft325 is offline
post #13 of 17 (permalink) Old 09-16-2009, 02:56 AM
Date registered: Dec 2006
Vehicle: 2000 E430 4Matic
where did you use the wire to open up the valve ? could you describe in detail please. I think my car might have the same issue.
thanks again !
Whether you think you can or cannot, Either way you're right!. by Henry Ford.
benz3000 is offline
post #14 of 17 (permalink) Old 09-16-2009, 06:15 AM
What I am thinking off is scaring me. If you look on the image attached here I think tank overfill check valve or the fuel filler tube check valve may be stuck.
I think it may be one of these because as soon as I try to put gas in the pump stops. If it was the charcoal canister shutoff valve than I would think that it may take a few seconds for the gas station pump to shut off at the beginning since the air can compress.
Any suggestions here?
Were you getting any error codes or was the check engine light coming on while all this was happening ?
benz3000 is offline
post #15 of 17 (permalink) Old 03-27-2010, 02:34 PM
Date registered: Mar 2010
slow filling gas tank
How far did you have to go in with the wire? I tried using a wire hanger to push through, but might not have gone far enough?
Thanks for your insight!!!
mmularski is offline
post #16 of 17 (permalink) Old 03-27-2010, 02:37 PM Thread Starter
hilarushi's Avatar
Quoted: 5 Post(s)
You will know when it first gets stuck. Once you unstuck it then the hanger could go all the way in, make sure you don't drop it in though.
post #17 of 17 (permalink) Old 03-27-2010, 02:53 PM
The problem was the canister shut off valve. the white valve on top of the fuel canister. Checked the canister while i was there to see any fuel trapped inside. None found. Replaced the valve and all is well !
So for those who are trying to resolve this issue, two things should be checked. This valve, and the other is the MOT valve that sits in the hood. I replaced the one in the hood first, with no change, but it was the cheaper option.
benz3000 is offline
    Filling tank with diesel klausc X164 GL-Class 11 03-18-2013 04:46 PM
    fuel line from tank to pump for 1996 c280 96_280_first mb W202 C-Class 0 02-20-2008 08:51 PM
    Fuel smell after filling gas tank Cmomma W203 C-Class 8 10-28-2007 05:40 PM
    loud noise from gas tank --> fuel pump? matteus W201 190-Class 1 01-19-2005 10:56 AM
    Fuel tank not filling completely corlissb W210 E-Class 1 02-01-2004 11:17 AM
