Cam shaft adjuster magnet - Mercedes-Benz Forum
post #1 of 37 (permalink) Old 03-23-2009, 02:06 PM Thread Starter
Veloman's Avatar
Date registered: Feb 2009
Vehicle: 2004 230SLK
Must admit I have been devouring all the good stuff on this forum. When I pulled the front top engine cover I was not surprised to see all the oily gunk there. When I pulled the connector on the cam adj magnet I saw oil in the connector. Looked down the wiring loom and saw no signs of oil. Guess I caught it in time. In any event I ordered a new magnet and cleaned up the front of the engine. In looking at the mounting bolts I saw a lot of oil had migrated along the threads. It looks to me as though some thread sealer would help the situation here. Is there a specific reason that oil seems to get inside the connector? I would think the magnet coil is molded around the wires and would seal any chance of oil getting in the connector. I plan to split the old unit apart (mine is riveted and not spot welded) and have a look at it. Has anyone done this? I sure hate to dispose of a good magnet just for an oil seepage. Perhaps there is a way to reseal this. Thanks to all who contribute here.
HarutyunVITO2001 likes this.
Veloman is offline
post #2 of 37 (permalink) Old 03-23-2009, 03:27 PM
Date registered: Dec 2006
Vehicle: 2000 slk230,firemist
No way to reseal. New magnet install and cleanup should solve problem. Use sensor safe gasket sealer. Mercedes does sell a plug that solves the oil creeping up the loom problem. Or just check it regularly. Regular problem, bad manufacturig.
ganndallff is offline
post #3 of 37 (permalink) Old 03-23-2009, 03:59 PM Thread Starter
Veloman's Avatar
Thanks for your answer gandaliff. Being a new owner I am surprised that Mercedes has not come up with a fix other than a wire dam to prevent oil migration. Guess I have a lot to learn!
Veloman is offline
post #4 of 37 (permalink) Old 03-23-2009, 09:29 PM
masterdog's Avatar
Vehicle: '01 SLK230 Kompressor, '95 C280, '98 BMW 528i, '86 BMW M635CSi EURO, '87 190E 2.3-16
Send a message via Skype™ to masterdog
Same here, oil in the plug, replacement cures it.
Good luck!
Someday I'll come up with something very clever instead of this
masterdog is offline
post #5 of 37 (permalink) Old 03-27-2009, 02:36 PM Thread Starter
Veloman's Avatar
Disassembled cam adjust magnet
My curiosity got the best of me and I removed the rivets from the old unit to see what sort of a sealing system they use. It's pretty basic with a silicon rubber washer on either end of the magnet coil. There are 2 ribs on each washer which press against the coil. The ribs on mine are mashed down which allows oil to seep through to the coil. There appears to be a center spool which is pressed into the coil body. This is where the oil can leak into the magnet body and out the connector tabs. I think washers could be made from 1/16" closed cell neoprene foam and the magnet reused. I would use small flat head machine screws to put it back together so a gasket change could be made easily. I will send some pictures of the assembly taken apart in a later post.
The new unit goes on the engine easily. I have a 1/4" drive torq head socket set so I cut a short piece of 1/4" keystock and with a 1/4" open end wrench, used it to tighten the screw which is behind the water temp sensor.
Veloman is offline
post #6 of 37 (permalink) Old 03-27-2009, 05:08 PM Thread Starter
Veloman's Avatar
Pictures of disassembled magnet assembly
Originally Posted by livefreeordie View Post
I would like to see those pictures, thanks in advance
Here are some quickee pics.
ID:	229639   Click image for larger version
ID:	229640   Click image for larger version
ID:	229641   Click image for larger version
ID:	229642   Click image for larger version
jguzman likes this.
Veloman is offline
post #7 of 37 (permalink) Old 03-28-2009, 04:49 PM
Shit-can the piece of crap, I, like you love to know why things fail, the problem is, in a car that costs this much, covered in Mecedes lore, should not fail on a regular basis.Don't get me wrong, for the last 5 yrs I've spent a fair amout of time and money fixing the "queen", and when its running good, its all been worth it. Check out consumer reports on new Mercedes, they rank low on dependability. Mercedes better wake up before Toyota buys them! Thank you for letting me vent!
post #8 of 37 (permalink) Old 03-28-2009, 06:34 PM Thread Starter
Veloman's Avatar
Just a tinkerer
I can understand the frustration of many members here on the forum. I started my sports car life with an MG many many years ago. Between the Lucas electricals and the leaking SU carbs it was always a chore to keep them running right. I not only like to know "why" but like to try to solve what the car companies can't seem to do. They build these wonderful cars and are destroyed by nickel and dime stuff. This failing part should have been redesigned years ago but it's brought them lots of dollars in parts and labor.
Over the years, my attitude has become, how can you bond with your car unless you get your hands dirty? I hope Toyota never buys them! Thanks for your comments.
Veloman is offline
post #9 of 37 (permalink) Old 03-29-2009, 07:29 AM
I feel better today. It just pisses me off that merc puts poorly designed K-40 relay, fan resistor, CPS, cam magnet, divertor valve, leaking emissions lines etc. They fail on a regular basis. Ive owned a lot of merc, my personal favorite, the 1967 250S, never had anything go wrong. Triumphs, MG's and Jaguar, you expect English electronics, not Mercedes.
Anyway, I love the pics, It really helps. Keep sending.
post #10 of 37 (permalink) Old 03-29-2009, 03:54 PM
Date registered: Dec 2003
Vehicle: 1999 SLK230 Kompressor
You hit the nail on the head. Your argument explains why a lot of industries are in bed with each other nowadays: they figured out that there is no PROFIT in building excellent machines for the masses. Just make them good enough to keep folks buying, oh and by the way, inflation has always been rising too, so how do these guys expect to compete in an ever-changing, ever-costly market place? why, save on cost wherever you can. Cuts here and there, the occasional low-ball offer for mediocre parts suppliers, heck, the repair shops have to eat too, so throw in a little planned obsolescence. The culture of manufacturing has changed completely; it used to be when something was built it was built to last the life cycle of the machine, but not so any more. The times have changed indeed!!!
Katika is offline
replacing camshaft adjuster magnet liquidusculade W202 C-Class 32 12-25-2016 07:10 PM
Camshaft Adjuster Magnet replaced but p1525 doesn't go away majidmo R170 SLK-Class 1 10-08-2008 06:40 PM
Camshaft Adjuster Magnet SLTriage R129 SL-Class 3 06-28-2007 11:30 AM
Cam adjuster solenoid connector broken WB9AXO R170 SLK-Class 11 03-22-2007 06:18 AM
Leaking Cam Adjuster Magnet David in Australia R170 SLK-Class 4 05-08-2006 11:24 PM
