Fuel Pump - Mercedes-Benz Forum
post #1 of 11 (permalink) Old 12-12-2008, 12:17 AM Thread Starter
Date registered: Oct 2008
Fuel Pump
Hi all,
Yeh i just came from Mercedes Parramatta, and they are charging me $1400 for just a fuel pump that is not including labour, do u guys recond it is a rip off??
or should i go ahead with it?
slk230_styles is offline
post #2 of 11 (permalink) Old 12-12-2008, 01:21 AM
oberoi's Avatar
Date registered: Mar 2006
Vehicle: 2010 C200 CGI /W203/SLK230/W202/230E/280SE
Quoted: 33 Post(s)
Order online - around $255 US - easy DIY
www.thebenzbin.com/ or http://replacement.car-stuff.com/par...owdc=true#top- plenty of sources
If you want it urgently try Silver Star Spares in Kingsgrove - they are pretty reasonable
I have the C Class Manual (same as SLK) if you want to know how to do it
Oberoi
oberoi is offline
post #3 of 11 (permalink) Old 12-12-2008, 11:05 AM
Arotished's Avatar
Date registered: Jun 2007
Vehicle: 1999 MB SLK 230
WOW, I got a high preformance Pierburg fuelpump for 250 dollars and installation taked 30 minutes.
1999 230 SLK
Arotished is offline
post #4 of 11 (permalink) Old 12-12-2008, 11:16 AM
forcefedboost's Avatar
Date registered: Jul 2008
Vehicle: 1999 MB SLK 230 Sport 5Spd
LMAO F**K them, they will be robbing you... You can easily get to your fuel pump... See in pictures below.... Its the silver thing with the blue band...
.................................................. ................................................^^ THIS ONE^^
It sits undernieth the car, behind a plastic cover. Passenger side rear. Very Simple to swap out, literaly plug and play, maby a couple of screws... Simple, Ill do it for 800including a flight out to where ever you are and a 6 pack of beer! lmao simple DIY!
-GHOST
1999 SLK 230 Kompressor
Silver With All Black/ REAL Carbon Int. (pics soon)
-Sport PKG
-Black AMG 17" Rims
Mods/Fixes
New ECU/ECM - New K40 Relay - Denzo Copper Plugs
Wide-Band O2 & Boost Guage - Custom Cubby Hole Pod - Switch; ON/OFF Guages
CX Front Mount (Painted Black)
H1 HID Kit Yellow Fogs
H7 HID Kit 6K White Low Beams
1 Pc Chrome Projector Headlights
5Pt Harness
265-40-17 Potenza RE01's Rear
Ebichi Lowering Springs
forcefedboost is offline
post #5 of 11 (permalink) Old 12-12-2008, 02:49 PM
oberoi's Avatar
Quoted: 33 Post(s)
You can get to Sydney for $550 ??
You just want some warm weather !!!
Oberoi
oberoi is offline
post #6 of 11 (permalink) Old 12-12-2008, 02:57 PM
Date registered: Sep 2008
Vehicle: '99 SLK230 sport
Arotished,
Can you give us the part number of this 5 bar fuel pump, I just might need one. Also, if you got this off the internet, where did you get it? Thanks alot.
ManicD3MEY3Z BUY MY STUFF
manicdemise is offline
post #7 of 11 (permalink) Old 12-12-2008, 02:59 PM
IdK he lives in australia! Hell yea ill find my way there for 550! I have family there, i wish i could go, and deff for the warm weather!
-GHOST
-Sport PKG
-Black AMG 17" Rims
Mods/Fixes
5Pt Harness
post #8 of 11 (permalink) Old 12-12-2008, 03:08 PM
Arotished's Avatar
Originally Posted by manicdemise View Post
Arotished,
Ebay my friend.
PIERBURG FUEL PERFORMANCE PUMP-360L/h-BETTER THAN 044 - eBay (item 300217315578 end time Dec-13-08 22:19:32 PST)
1999 230 SLK
post #9 of 11 (permalink) Old 12-12-2008, 03:11 PM
oberoi's Avatar
Quoted: 33 Post(s)
Thebenzbin shows the Pierburg SKU as WO 133-1600340 ($291)
This is for the pre facelift model - could be a diff pump range for 2000-2004 models altho' the ebay seller says the Pierburg will do both
Oberoi
oberoi is offline
post #10 of 11 (permalink) Old 12-12-2008, 03:28 PM
Date registered: Sep 2002
Vehicle: SLK 230 (now gone), SLK 350 Facelift
Sure that its the fuel pump not the K40 relay that needs replacing.........
robint
robint is offline
    Changed my fuel pump to fix my fuel gauge, and got an added BONUS. mikewired W163 M-Class 15 03-04-2012 09:52 AM
    1988 260e w124 no fuel...changed fuel pump and relay!! salthepal W124 E,CE,D,TD Class 11 01-07-2012 09:32 AM
    fuel air mix / testing fuel pumps and pump pressure william.wood W126 S,SE,SEC,SEL,SD,SDL Class 0 11-09-2005 12:32 PM
    380sel where is the fuel pump fuse? have no power to pump meggala W126 S,SE,SEC,SEL,SD,SDL Class 3 08-02-2005 04:44 AM
    Update on Fuel Gauge Problem: Got Fuel Pump Replaced Today tjhsiao W163 M-Class 4 10-25-2002 05:47 PM
