C1025 - Mercedes-Benz Forum
post #1 of 10 (permalink) Old 10-18-2008, 12:59 AM Thread Starter
Arotished's Avatar
Date registered: Jun 2007
Vehicle: 1999 MB SLK 230
C1025
Anyone have had this code?
C1025 CAN Communication BAS communication with ESP control unit faulty
CAN - Communication
- Complete CAM communication
- The traction control unit
- CAN - Signal : Breaklight switch
- CAN - Signal - Wheel RPM
I have changed the breaklight switch 3 mounths back, what is the next in line?
I also get the P1236, guess this is the clutch on the supercharger (dont I dont use but have installed)
1999 230 SLK
Arotished is offline
post #2 of 10 (permalink) Old 10-19-2008, 01:09 PM Thread Starter
Arotished's Avatar
No one? The code is away not but still, if it comes back again
1999 230 SLK
post #3 of 10 (permalink) Old 10-19-2008, 07:39 PM
MBSLK-AMG's Avatar
Date registered: Jul 2008
Sorry. I've never had that problem before. Have you asked the mercedes service department?
If you can't be a good example, at least be a horrible warning.
MBSLK-AMG is offline
post #4 of 10 (permalink) Old 10-20-2008, 04:09 AM
dwieden's Avatar
Date registered: Jun 2006
Vehicle: 02 - 32 (Stock); 99 SLK230 (RIP); 81 CJ7 (Fully MOD)
I've got a CAN problem before. It's related to the ECU though and needed dealer to fix. Totalled the car before I get to it
DW
dwieden is offline
post #5 of 10 (permalink) Old 10-21-2008, 09:23 PM
Kobus's Avatar
Date registered: Apr 2007
Vehicle: 2001 SLK 320(205K Miles), 2002 E320 Special Edition(174K Miles)
I had it on mine when the battery was bad. (< 11.5 volt I think.). But then I had a whole lot a funny errors reported with the bad battery.
Only two thing are infinite, the universe and human stupidity, and I'm not so sure about the former.
Albert Einstein
Honest politicians are like UFOs. Most people believe that there must be some out there somewhere, but nobody has yet been able to prove their existence.
Kobus is offline
post #6 of 10 (permalink) Old 08-04-2009, 09:38 AM
Date registered: Mar 2009
HI Mate,
I've got the same code c1025, please be so kind t advise what was the final verdict on this problem.
Kind regards
Willem
Willa is offline
post #7 of 10 (permalink) Old 08-15-2009, 01:19 AM
Date registered: Jul 2009
I also got C1025.
I have trouble with ESP not kickin in sometime.
Did you solve your C1025 issue?
merald is offline
post #8 of 10 (permalink) Old 08-15-2009, 01:59 AM
Chris A's Avatar
Copy paste from another site
code C1025 is defined as " CAN Communication BAS communication with ESP control unit faulty." This basically means that the BAS module is not networking correctly with the ESP module, commonly this is usually a glitch code, unless it returns more than once. I would have the system reset and see if the code returns immedialty, of not monitor it and see how long in between settings. In a case where the code returns immediatly, the BAS or ESP module is faulty. This system requires a Mercedes level scan tool to test.
Women can fake orgasms. . . . men can fake whole relationships.
Chris A is offline
post #9 of 10 (permalink) Old 08-15-2009, 02:03 AM
Got an really bad skid on the car in a roundabout when you used to the ESP kickin in if needed. It couldnt be any contact-issues between the two controllers? Is the "CAN-bus" a cord between them or how is the logic there?
merald is offline
post #10 of 10 (permalink) Old 07-21-2011, 02:39 AM
merc131's Avatar
Vehicle: w126 300SD 1981 - Vito W638 108 CDI 2000 - W209 CLK cabrio 2003
On my slk230 from 1998 I get the same code. (with the Mercedes DAS multiplexer). Cannot get it erased. ABS/ASR and the BAS lights stays on.
I have read a lot of topics, but I am having trouble to determine what the CAN Bus exactly is. I think it means Controller Area Network. And that it controls several inputs.
Where can I find that CAN Bus? Maybe a stupid question but I am dutch and having some trouble with some technical words.
merc131 is offline
