Brake pads/discs change - Mercedes-Benz Forum
post #1 of 52 (permalink) Old 10-06-2008, 06:10 AM Thread Starter
isarescu's Avatar
Date registered: Jan 2008
Vehicle: SLK 230 Kompressor, 2001
How hard it is to change them on a scale from 1 to 10? Can I do it my self? Thank you!
isarescu is offline
post #2 of 52 (permalink) Old 10-06-2008, 06:15 AM
dwieden's Avatar
Date registered: Jun 2006
Vehicle: 02 - 32 (Stock); 99 SLK230 (RIP); 81 CJ7 (Fully MOD)
It's pretty easy, especially the front. On a scale 1-10, 1 being the easiest, I'll give it 5.5. There should be a discussion here awhile back about it. I think Bazzle did a write up on it.
The front disk just unbolt from the hub (requires allen key).
Just press the pad/cylinder back a little to relieve the pressure on the disk. Same thing with the back, except there's a drum shoe assembly behind the hat for the parking brake.
Don't forget to check the fluid afterwards, & test the brake
DW
dwieden is offline
post #3 of 52 (permalink) Old 10-06-2008, 08:02 AM
damo320's Avatar
Vehicle: 2001 SLK 320 auto, 2006 CLS320 CDi.
Yep pretty straight forward if you have all the right tools and follow the guides dwieden mentioned which are in the old techinal sticky which can be found through the tech sticky at the top of the main page. I did my fronts a few mounths ago and finally did the rears and painted the calipers silver this weekend, the hardest part was getting the adjustment on the hand brake right.
damo320 is offline
post #4 of 52 (permalink) Old 10-06-2008, 08:17 AM
Bruce R.'s Avatar
Vehicle: 2002 SLK 32 AMG, bone stock. 1987 190E 2.3-16 valve (destroyed). 2005 E320 new toy.
Quoted: 41 Post(s)
Here's the rear brakes: SLK Rear Brakes
This is the front brake proceedure on the SLK 320, but the 230 isn't all that much different: SLK320 Brakes
If nothing else, you can see if you want to try it yourself....
"Negotiating with Obama is like playing chess with a pigeon, the pigeon knocks over all the pieces, on the board and then struts around like it won the game."
Vladimir Putin
"They have gun control in Cuba. They have universal health care in Cuba. So why do they want to come here?"
Paul Harvey 8/31/94
"The only people who have quick answers don't have the responsibility of making the decisions."
Justice Clarence Thomas
Bruce R. is offline
post #5 of 52 (permalink) Old 10-06-2008, 08:59 AM
Kirill's Avatar
Date registered: Jul 2003
Vehicle: 01 SLK 320 MT6
I give it 3 (If you search and read everybody's experience) And 7 if you don't.
10 if you give to shop and have to worry what they did wrong.
To get the front rotors out - you need to remove calipers (no need to disconnect break lines) - to do it - you need to remove two bolts (they are on blue locrite - hard to break free - you big extension on your wrench) when reassemble - put them back on blue locrtie thread sealant.
Use Brebmo cross drilled disks and pads of your choise
Kirill
Kirill is offline
post #6 of 52 (permalink) Old 10-06-2008, 10:15 AM
Michael Pillay's Avatar
Date registered: Oct 2003
Quoted: 91 Post(s)
Easy job. With the right tools you will not have a problem. The only snag that I ran into was that the front rotors were rusted onto the hub. PB blaster and three arm puller got in of.
Mike
Michael Pillay is offline
post #7 of 52 (permalink) Old 10-06-2008, 11:26 AM Thread Starter
isarescu's Avatar
What is "blue locrite"? Thanks!
isarescu is offline
post #8 of 52 (permalink) Old 10-06-2008, 11:37 AM
Date registered: Mar 2008
Vehicle: SLK32 AMG
I think he meant Loctite,
Loctite Worldwide, United Kingdom and Ireland
It is a sort of glue compound that is used to stop bolts/nuts coming loose, and often used on brake components as a safety feature.
Billy610 is offline
post #9 of 52 (permalink) Old 10-06-2008, 03:03 PM
Kirill's Avatar
Yeph
Kirill
Kirill is offline
post #10 of 52 (permalink) Old 10-06-2008, 03:23 PM
royeco's Avatar
Date registered: Jun 2008
Vehicle: SLK230
How do you hold the rotor when you loosen the bolt?
royeco is offline
    Brake Pads and discs topcat2006 V-Class 1 09-12-2008 01:18 AM
    brake pads and discs replacement paul001 W245 B-Class 17 06-03-2008 01:35 AM
    Do I have uber brake pads and discs? ALephart R170 SLK-Class 3 02-26-2008 01:07 PM
    brake discs and pads diam0ndb0y C208/A208 CLK-Class 10 01-22-2006 08:20 PM
    How to: Change brake pads/discs cagalbraith W203 C-Class 3 02-07-2005 11:38 AM
