» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Roadster Forums > R170 SLK Class
Old 07-24-2008, 05:19 AM   #1 (permalink)
cw4bryant's Avatar
Date registered: Jul 2008
Vehicle: 99 SLK 230
Hydraulic Fluid for Roof Pump
Does anyone know what type of hydraulic fluid is used in the pump for refill and can it be simply purchased at your local auto parts store?
cw4bryant is offline   Reply With Quote
Old 07-24-2008, 07:46 PM   #2 (permalink)
silberpfeil1234's Avatar
Date registered: Jul 2005
Vehicle: 1998 Mercedes 230 SLK
Hydraulic fluid: Mercedes part#A 000 989 91 03 10, approx 400 ml for a complete fill. It is produced by Aral Vitamol as ZH-M hydraulic fluid. I am not aware of any proven substitute. However, the cost is reportedly only $15.00 per liter. Mercedes also uses this oil in their hydropneumatic suspension, and all the other convertibles old and current so dealers should have stock.
Silver 1998 230 SLK
H&S 255 mm crank pulley
GIAC chip
4 bar FPR
Vaeth intercooler and stainless steel roll bars
Full Supersprint exhaust
Lights: LEDs rear, Bi-xenon headlights
PIAA Ion yellow fog lights
Clear side markers and third brake light
silberpfeil1234 is offline   Reply With Quote
Old 03-23-2009, 04:01 PM   #3 (permalink)
Date registered: Mar 2009
Vehicle: 1998 SLK230
Where do you put the additional fluid in at? Thanks!
pastbart is offline   Reply With Quote
Old 03-24-2009, 03:55 PM   #4 (permalink)
oberoi's Avatar
Date registered: Mar 2006
Vehicle: SLK230 (2000) C180/230E/280SE
[quote=silberpfeil1234;2983509]Hydraulic fluid: Mercedes part#A 000 989 91 03 10, approx 400 ml for a complete fill. It is produced by Aral Vitamol as ZH-M hydraulic fluid. QUOTE]
Just as an aside, my local Benz indy sold me the ZH-M fluid 02615 (made by febi-bilstein) for the power steering. I assume it's the same stuff?
Bruce
oberoi is offline   Reply With Quote
Old 03-24-2009, 10:36 PM   #5 (permalink)
Date registered: May 2008
Febi Bilstein # 02615 Hydraulic Fluid ZH-M may be cheaper.
Remove the allen bolt plug on the top of the pump, run a tube into the hole. Carefull not to drop the plug, space is tight in there.
salty325 is offline   Reply With Quote
Old 03-25-2009, 03:53 PM   #6 (permalink)
Thanks for the info. The top is working again! Is the ram at the top/windshield interface hard to replace?
Old 03-25-2009, 08:47 PM   #7 (permalink)
Date registered: Apr 2007
Vehicle: 98 red 230 slk
Yes it is! But can be done. Do a search on top lock replacement...
cacecef is offline   Reply With Quote
Old 04-08-2009, 04:41 PM   #8 (permalink)
Thanks for the lead. I'll check it out. Does anyone know if a ram can be rebuilt? Seals, etc?
Old 04-08-2009, 05:33 PM   #9 (permalink)
rpiotro's Avatar
Date registered: Sep 2007
There have been a couple of threads here about people that were going to attempt it but, I don't know if any of them were actually successful. Part of the problem is that the fitting is not practical to remove. A replacement comes as an assembly with the hose.
In other words, rebuilding is not practical but let us know if you decide to tackle it.
rpiotro is offline   Reply With Quote
Old 04-08-2009, 05:37 PM   #10 (permalink)
slk230280's Avatar
Date registered: Apr 2006
Vehicle: 2003 slk230
[quote=oberoi;3388551]
Bruce
Was told by MB dealer that steering and roof fluid are not the same. Has anyone tried?
slk230280 is offline   Reply With Quote
Roof lock cylinder leaking hydraulic fluid wilko R170 SLK Class 28 08-29-2008 05:28 PM
Vario Roof Hydraulic fluid check? blackdog R170 SLK Class 4 03-12-2008 02:56 PM
help! hydraulic pump probs for roof gpreyes R170 SLK Class 3 07-05-2007 07:10 PM
Anyone know how to fill Hydraulic Fluid for ROOF? zanshadow R170 SLK Class 1 04-04-2004 05:44 AM
filling roof hydraulic fluid NY_in_TX R170 SLK Class 7 12-03-2003 12:57 PM
