Cruise Control Stalk compatability - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 07-23-2008, 03:09 PM Thread Starter
kieran_sly's Avatar
Date registered: May 2008
Vehicle: 98 SLK 230K
I have to replace my cruise control stalk/switch, so I ordered the part from a breakers yard.
When it arrived I noticed it differs from my current stalk as it has the Limit/Cruise "Speedtronic" push in function.
Will this part work firstly and if so, a) as a normal cruise control i.e 4 direction stalk or b)with the added Limit function.
Thanks
kieran_sly is offline
post #2 of 5 (permalink) Old 07-24-2008, 02:34 AM
Date registered: Sep 2002
Vehicle: SLK 230 (now gone), SLK 350 Facelift
Don't know if it will work or not but it is probably from a later car (post face lift??) as I thought all UK cars had the speed limiter (yellow light appears on stalk when active) as standard. The cruise function works in the normal 4 way mode on the later stalks - suspect the push on the end just activates an additional; circuit - which may or may not be hidden in the electronics already.
robint
robint is offline
post #3 of 5 (permalink) Old 04-06-2012, 12:47 PM
RichardTK's Avatar
Date registered: Jul 2009
Vehicle: 1998 SLK 230 Kompressor, 1993 500 SEC
Don't suppose anyone ever answered this elsewhere, did they? Mine lacks the Speedtronic lever, I'd like to fit it if I can.
Yellow 1998 SLK 230 Kompressor, 1993 500 SEC
160+ cars in 24 years...
Past: W168, W123, W124, R129, W168, W201, S210, C124
RichardTK is offline
post #4 of 5 (permalink) Old 04-06-2012, 01:10 PM Thread Starter
kieran_sly's Avatar
The stalk from the later model worked fine but only gave me the original functionality. No speedtronic or speed limiter.
post #5 of 5 (permalink) Old 04-06-2012, 01:16 PM
RichardTK's Avatar
Great - thanks! I wasn't expecting a reply from such an old thread. So it'll fit, but there is more needed - and you've got a '98 UK-spec SLK too, so it's probably correct that my car lacks Speedtronic.
    Turn Signal/Cruise Control Stalk loose! Joey6 W140 S-Class 2 06-23-2009 06:17 PM
    Cruise Control - Stalk has come out! kieran_sly R170 SLK-Class 13 07-21-2008 09:41 AM
    CLK cruise control stalk?! IsellBenz C208/A208 CLK-Class 1 02-11-2008 03:40 PM
    Cruise Control Stalk mental issues... John_Best W163 M-Class 11 07-16-2005 12:58 AM
    Anybody tried shortening the cruise control stalk? Larry Blackhurst R170 SLK-Class 0 10-16-2001 07:58 AM
