» Sponsors
» Sponsors
BenzWorld.org is the premier Mercedes Benz Forum on the internet. Registered Users do not see the above ads.
Old 07-06-2008, 10:46 AM   #1 (permalink)
Yendor's Avatar
Date registered: Jul 2006
Vehicle: 1999 SLK230 Kompressor
Roof Troubles - Not the normal things...
After checking every last switch in the Vario roof system, I still cannot get this thing to open properly.
It begins to open, then when the roof section is halfway open (rear window part nearly vertical), it stops. No reaction from there, except killing ignition lets the thing settle into the trunk/boot. The trunk lid remains open. Restoring power and trying the roof switch in either direction makes the hydraulic pump run, but it seems to be trying to push the folded roof assembly deeper into the trunk cavity.
Does anyone have information about the system:
1. A blow-by-blow logic flow diagram of what happens when in the process of opening/closing the roof.
2. A pic/description of where the module is that controls the roof process.
There is obviously some logical condition that comes into play at the mid-point of roof opening. I would like to tap into the signals from all the switches to monitor this process nad see where the fault is. I likely have a wiring fault, as the switches are all OK.
I've dug deeper into the roof system than what I have heard about on these forums, and have done extensive searches here and elsewhere, and I'm stuck. I'm an EE so I'm not afraid of the electronics (I'll make my own damned controller if needed)...
Thanks to all on here - this forum has been a godsend for info about these rather poorly-documented little cars!
"I have no recollection of those events."
- Ronald Reagan
Yendor is offline   Reply With Quote
Old 07-06-2008, 01:04 PM   #2 (permalink)
Bazzle's Avatar
Date registered: Apr 2005
Vehicle: 1998 SLK230
Ive posted as much as I have a few time, sw cct etc. Have you read the codes? or checked the fluid?
File Type: txt Switch flashes.txt (689 Bytes, 37 views)
Bazzle is offline   Reply With Quote
Old 07-07-2008, 06:58 AM   #3 (permalink)
Yendor's Avatar
Thanks! I will tap into all the switch lines and see what's going on!
Old 07-07-2008, 05:21 PM   #4 (permalink)
oberoi's Avatar
Date registered: Mar 2006
Vehicle: SLK230 (2000) C180/230E/280SE
How long since you lubed the hinges? - mine was similar but blew the 40 amp main fuse repeatedly just after the trunk opened and roof started to rise - lubing hinges fixed it
Oberoi
oberoi is offline   Reply With Quote
Old 07-10-2008, 08:37 AM   #5 (permalink)
Date registered: Jun 2008
Dear Yendor,
i was referred to this site by bazzle and saw his response to your inquiry about the process involved in the retractable top of an slk. I too have a 99 slk 230 kompressor with a top problem and have done considerable research on iot without any definitive help so far. I hope you can shed some light on this; i will be most grateful. My trunk opens all the way and then the process stops (The top is up and won't retract.) I had it diagnosed at MB dealer and they said top sw are faulty and wanted $900.00 to repair. I said no. So here I am, wandering what to do next. IF I release the hydraulic pressure on the pump with the hex wrench, I am fairly certain that I can then unlock the latches with the access port in the roof. So, then what? Do I repressurize the pump to seeif the remaider of the process will operate? It seems to me from studying bazzle's schematic that the opening of the trunk and the unlocking of the roof at the winshield pillar are all part of step 1. So, why would the trunk open and the roof not unlatch if the same switch operates by steps and the trunk does open? I know nothing about electronics and I know that you do and hope you may have some answers. Also, do you think that if I get the top down by using 50/50 method (first half switch, second half manually), that I run the risk that the rear quarter windows won't come up again when I try to bring the top up with the electronics/hydraulics? Any thoughts are appreciated.littleb.
littleb is offline   Reply With Quote
Old 07-10-2008, 12:26 PM   #6 (permalink)
rpiotro's Avatar
Date registered: Sep 2007
Vehicle: 1998 SLK230, 2009 Pontiac G8 GT
Oberoi
What are you using to lube the hinges? Are there any plastic parts? Might a spray Teflon lube be good?
rpiotro is offline   Reply With Quote
Old 07-10-2008, 01:59 PM   #7 (permalink)
Kirill's Avatar
Date registered: Jul 2003
Vehicle: 01 SLK 320 MT6
How it stops ? Is the hydraulic pump stops or pumps is still going, but roof is not moving ? Any error signals like flashing roof switch beeps ? Any garbage caught up in the mechanism ?
Kirill
Kirill is offline   Reply With Quote
Best things / Worst things about where you live FeelTheLove Off-Topic 50 07-12-2007 09:24 PM
A/C troubles 79Mercy W123 E,CE,D,CD,TD,TE Class 0 06-25-2007 09:25 PM
Idling Troubles....Please Help RPeters W126 S,SE,SEC,SEL,SD,SDL Class 1 08-15-2004 06:13 PM
Is it normal? My SLK accelerates a bit faster than normal after… funfun R170 SLK Class 2 11-06-2003 06:49 AM
MORE TROUBLES ALEX G-Class 4 02-15-2002 07:17 AM
