Old 07-05-2008, 03:01 PM   #1 (permalink)
Date registered: Mar 2007
Vehicle: MB SLK 230 AMG (1997)
Error code P0341 help please
I was out driving today and the car got into limp mode or something, scanned it and found the code P0341 Camshaft Position Sensor Circuit Range/Performance
anyone have some DIY how to change this ? some pictures ?
thanks in advance.
Biosphere is online now   Reply With Quote
Old 07-05-2008, 05:35 PM   #2 (permalink)
Date registered: Jul 2005
Vehicle: 1998 Mercedes 230 SLK
The best is to test the engine online with a scanner to see what's going on.
My best guess: oil has leaked into the the sensor and disrupted proper signaling to the engine computer causing the limp mode. This is a common issue with the M111 - the variable intake camshaft likes to leak oil into everything as capillary forces draw the oil even along into distant cables. Remove the front plastic cover and check all plugs for oil. the camshaft sensor is the one sitting right on the camshaft cover (the gold-colored lid on the right). If there is oil try cleaning the contacts and see whether this remedies the issue. Mercedes provides updated oil protection cable for the facelift models not pre-facelift but former can be adapted for the facelift with some mods.
Silver 1998 230 SLK
H&S 255 mm crank pulley
GIAC chip
4 bar FPR
Vaeth intercooler and stainless steel roll bars
Full Supersprint exhaust
Lights: LEDs rear, Bi-xenon headlights
PIAA Ion yellow fog lights
Clear side markers and third brake light
silberpfeil1234 is offline   Reply With Quote
Old 07-05-2008, 06:29 PM   #3 (permalink)
livefreeordie's Avatar
Date registered: Oct 2007
Vehicle: 02 SLK230 Komp. 08 Honda CRV
If its leaking its best to replace it, around $40 then clean both surface's, place a light coat of silicon sealant before replacing the cam shaft magnet. Very simple job, takes about 5 min.
livefreeordie is offline   Reply With Quote
Old 07-06-2008, 03:13 AM   #4 (permalink)
Thanks for the replay guys, i scanned it again now and got a new code.. :\
Does this mean both sensors are bad ?
thanks for all advices..
Old 07-06-2008, 05:46 AM   #5 (permalink)
Possibly but not necessarily so.
Let's say there's oil leakage and it went into the cables all the way up to the engine computer: this could cause all kinds of electrical shorts and misreadings. So,if there oil on the camshaft senor plug, it might be good to check out the computer box (black box next to the battery) for oil as well. If there's oil in that area the bad news is that all cables and possibly the computer have to be replaced = $$$. If not, and oil is only at the senor level, still clean the latter and see whether CEL goes away. This may also cure the P0130 in case the misreading have caused rich fuel/air mixture and carbon build up on the O2/lambda sensor as it might clean itself once things are again ok on the front end.
However, this may also a problem by itself - again the error alone doesn't provide a diagnosis - the sensor could be fine but connectors or wires to and from aren't. A faulty O2 sensor read will rarely cause limb mode, though, and sensors are supposed to be good for about 100k miles before one should replace them.
So don't buy spare parts yet unless you or the mechanic have a good idea about the likely cause.
Old 07-06-2008, 04:24 PM   #7 (permalink)
Originally Posted by Bazzle View Post
havent had the time yet,,, but i will..
but that sensor in that link is not the same as he mentioned ?
Old 07-06-2008, 04:51 PM   #8 (permalink)
Yes, it is - sorry, the sensor sits indeed around the corner as shown in that link.
Code P0341 ETP W210 E-Class 6 06-19-2008 10:07 AM
Error Code sergiu W163 M-Class 4 05-27-2008 02:55 AM
Trouble Code P0341 - effect? oztds R170 SLK Class 7 01-15-2007 04:46 AM
cc 3 error code willieg General Mercedes-Benz 0 06-25-2004 03:23 AM
cc 3 error code willieg General Mercedes-Benz 0 06-25-2004 03:22 AM
