Old 06-28-2008, 02:59 AM   #1 (permalink)
CYP
CYP's Avatar
Date registered: Nov 2006
Vehicle: 2002 SLK230 Kompressor
Airbag / SRS Ecu change
Hi all,
I need your help.
I have 2002 Mercedes SLK230 (R170) which have faulty Airbag/SRS Ecu. according to the Mercedes Dealer there is ECU Error / Diagnostic communication error but they are not sure if I buy new one that it will %100 cure problem.
the dealer told that I should pay for it even if it is not cure problem
by the way it is about 600/- UK pounds + labour ????
I bite the bullet and bought second hand with same part number (A) 0018200826 (08)
it is came from R170 SLK32 AMG which seller quarantee that vehicle never involved in any accident.
according to the link below it says new part does not need
to be coded
this is for R170 SLK230 vin start with 170.449 (my vehicle ECU)
http://www.detali.ru/cat/oem_mb2.asp...SGR=287&SGN=09
this is for R170 SLK32 AMG vin start with 170.466 (second hand ECU)
I might choose wrong way because every airbag/srs ecu has vehicle VIN number in it that factory fit it.
is there any way to change its VIN number with my vehicle?
or is it only for accident report if vehicle involve in any accident to prove which car has that airbag/srs ecu?
if it is in working order what is my chance to solve problem with that second hand airbag/srs ecu?
I am totally confused now. Need yours important opinions.
cheers
Ali
Previous vehicle was Pajero 1991 2.5 SWB Intercooler Turbo (MK2) I still miss this vehicle
1981 Ford Granada 2.8 Ghia saloon MK2 (Facelift model)
Mitsubishi Pajero(Montero) Album http://www.photobox.co.uk/album/2168609 [IMG]
MB SLK230 Album http://www.photobox.co.uk/album/4711209
KNOWLEDGE IS NOTHING IF YOU DONT SHARE IT.
Last edited by CYP : 06-28-2008 at 07:21 AM. Reason: (08) added to the part number
CYP is offline   Reply With Quote
Old 06-28-2008, 06:28 AM   #2 (permalink)
R170 Moderator and PITA
Bruce R.'s Avatar
Vehicle: 2002 SLK 32 AMG, bone stock. 1987 190E 2.3-16 Valve, NOT bone stock...
If you are asking if you can exchange air bags from a wreck to your car, yes you can. The air bag triggers are not in the bag itself, and if the bag fits correctly you are good to go.
I changed out the air bag in my 190E because mine was starting to split at one of the seams. The "new" one came from Potomac German Auto, a local wrecking yard. I have no idea what year it came out of, or what the VIN was, it don't matter if the part fits right.
If you do the job yourself, be sure to disconnect the battery first, and leave it un connected while you work.
2002 SLK 32,
1987 190E 2.3-16 valve
"A vote is like a rifle: its usefulness depends upon the character of the user."
Theodore Roosevelt
"In any survival situation, you should try to keep your friends alive as long as possible. They stay fresh longer that way.
Unknown
Bruce R. is offline   Reply With Quote
Old 06-28-2008, 07:02 AM   #3 (permalink)
CYP
CYP's Avatar
Hi Bruce R,
first of all thanx for promt reply.
I asked if I can exchange Airbag Control Module (also known as SRS Control Module) which is situated at under radio/head unit in front of the gear selector under center console behind ashtray.
I try to add picture of module which can help for you to identify which part I am talking about.
this is CLK320 Airbag Control Module but looks same with SLK or some other MB Airbag Control Module.
by the way if I disconnect battery for several hours will that help to erase all soft and hard codes from this module? check the link below it has some info about hard and soft codes on module.
http://www.benzworld.org/forums/gene...hlight=srs+ecu
cheers
Ali
Old 06-28-2008, 08:29 AM   #4 (permalink)
Bruce R.'s Avatar
The part number code on the module doesn't indicate that it was built for a specific module Benz, so it may be safe to assume that it is correct for a number of classes. If the part number is the same as the one in your car, you should be good to go. If not, don't use it unless you have a GOOD cross reference chart that states it is an OK swap.
On reading the link, there is a good troubleshooting info there, go with it and check things as they indicate first.
Pulling the battery leads will erase the stored codes in the computer, but I doubt that there are any codes stored in that module to erase.
Old 06-28-2008, 02:06 PM   #5 (permalink)
CYP
CYP's Avatar
hey are there more opinions???
Old 06-28-2008, 02:14 PM   #6 (permalink)
Bazzle's Avatar
Date registered: Apr 2005
Vehicle: 1998 SLK230
If same part number just swap the module over.
Remove neg term for at least 10 mins. 30 mins to remove soft codes and reset most drive parameters.
Bazzle is offline   Reply With Quote
Old 06-28-2008, 02:30 PM   #7 (permalink)
CYP
CYP's Avatar
hi Bazzle,
thanx a lot for your reply.
Part number is exactly same but, if you know answer all other numbers on the module should match with my vehicle's module?
I mean other numbers SKU number etc. (I dont know exactly what is this for but noticed that some sellers on ebay mention SKU number of module also)
by the way tomorrow I 'll first disconnect battery and after reconnect it will check if "Passenger Airbag Off" or "SRS" light will lid.
becuase "Pasenger Airbar Off" light is always on and "SRS" light lids about 5 minutes then it lids again after about 15 minutes!!!!
it seems SRS module finds fault every 10-15 minutes at unit check cycle and lids up.
if SRS module faulty which electronic part send "SRS" light order to lid and warn driver!!!
I really couldnt find any explanation to this situation.
Ali
Old 06-28-2008, 05:55 PM   #8 (permalink)
Bazzle's Avatar
Check connector under passenger seat is plugged in fully.
Old 06-29-2008, 01:45 AM   #9 (permalink)
CYP
CYP's Avatar
hi Bazzle,
believe me that I checked connector under passenger seat at least 20 times after I bought this vehicle. even I disconnect and clean contacts (of course while switch was off)
no cure
I dont understand something;
if module is faulty which part causes red "SRS" light lid left part of the dashboard ??????
cheers
Ali
Old 06-29-2008, 09:15 AM   #10 (permalink)
Date registered: Aug 2003
Vehicle: 95 C220
yea if the modual goes faulty or anything goes faulty in the air bag system, the light comes on
when replacing the airbag modual, make sure u disconnect the battery. plug n hte new modual, then reconnect the battery. it may need to be initialized by the dealer(some makes of car do, some dont).
don't buy a used modual if the airbags were deployed on the car (once the airbags on a car has been deployed, the modual goes bad)
fastmayte is offline   Reply With Quote
SRS Airbag replacement RedLiner R129 SL Class 1 11-28-2007 05:47 PM
SRS and Airbag light almost always on ALT W210 E-Class 3 09-01-2007 02:57 AM
SRS AIRBAG thinkman W164 M-Class 4 04-18-2006 12:57 PM
SRS/Airbag Light dmico2 W163 M-Class 6 08-18-2005 10:16 PM
SRS airbag Guest (MBNZ) W202 C-Class 0 01-30-2002 11:10 PM
