» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Roadster Forums > R170 SLK Class
Old 06-25-2008, 03:11 AM   #1 (permalink)
Bazzle's Avatar
Date registered: Apr 2005
Vehicle: 1998 SLK230
CPS replacement 230 V6 similar
Crankshaft position sensor (left rear of engine block on top of flywheel housing)
I had a PM re this so I will post again. Thanks Oberoi for the extra pix
Remove connector (2 diff types, 2 pin and coax (shown))
Remove torx screw.
Wiggle cps out.
Note: It may be tight due to the hole it slides in not being painted and rust forms. Persevere.
Clean hole and wipe with smear of grease before inserting new.
Some models have an air valve half covering cps making access a little bit harder.
Bazzle is offline   Reply With Quote
Old 06-25-2008, 07:21 PM   #2 (permalink)
markhsoares's Avatar
Date registered: Oct 2006
Vehicle: SLK230, ML320, B200
Thanks for the info, great pics make all the difference.
Regards
Mark
markhsoares is offline   Reply With Quote
Old 06-25-2008, 11:10 PM   #3 (permalink)
BenzWorld W203 Host
Buellwinkle's Avatar
Vehicle: C230K Sport Sedan
Amazing that something so small can cause so much trouble. A lot easier to work on with the engine out like in those pictures.
CPS failure symtoms but it's not the CPS problem joeml W163 M-Class 3 06-05-2008 11:05 AM
230 Air Filter Replacement Mike in NC R170 SLK Class 4 04-01-2007 08:33 PM
98 SLK 230 Door Speaker Replacement! dc9b727 Audio & Telematics Forum 0 06-03-2005 08:42 PM
230 GE LWB motor replacement islander G-Class 1 02-28-2004 07:34 AM
SLK 230-2001 tire replacement/brake pad replacement Guest (MBNZ) The Discount Tire Direct Tire, Wheel, Brake & Suspension 1 03-09-2002 11:08 PM
