» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Roadster Forums > R170 SLK Class
Old 06-06-2008, 06:13 PM   #1 (permalink)
Date registered: Apr 2008
How to change belts on 98 SLK230
Changing belts in easy. There is no need to pay someone to do it.
There are two belts. Of course, take the outer belt off first. Study the way it runs around the pulleys so you won't be scrathing your head wondering later how to run it when you put the new one on. I took a few pictures with my digital camera in case in needed them later.
Find the tensioner pulley. You will see a bolt in the middle of the pulley with a 15mm nut on it. I could not get my 1/2" ratchet and socket to fit between the nut and the fan shroud, so I used a 3/8" ratchet and still had a hard time getting it on.
Turn the tensioner counterclockwise until you can get the belt off a pulley. Since I had the car up on ramps to change the oil and therefore had the engine cover off too. I thought it looked easier to change it from the bottom. It took some effort to move the tensioner enough to get the belt off, the smallest pulley, which also happens to be the lowest pulley so it was easy to do from underneath.
Next, working from the top of the car, I took a 1/2" ratchet with 15mm socket and released the tension on the belt. The tensioner is located more or less in the middle of the pulleys on that belt. This belt came off easily - maybe 30 seconds.
To install the belts, just release the tensioner on the back belt first and rethread the belt. So the same for the front belts.
Before you start the car, make sure that the belts are properly seated on all the pulleys. If you are off one tooth on one pulley, you could break that belt, maybe both, and possibly a lot of other things under the hood.
AutoPier is offline   Reply With Quote
Old 06-06-2008, 06:21 PM   #2 (permalink)
Date registered: Mar 2007
Vehicle: MB SLK 230 AMG (1997)
nice guide, but feel free too upload pics
Biosphere is offline   Reply With Quote
Old 06-06-2008, 06:32 PM   #3 (permalink)
~BANNED~
linh's Avatar
Vehicle: 06' CLK 500 Cabrio, 01' CL 55, 01' CLK 430, 04' Civic
Search for Bazzle post.
linh is offline   Reply With Quote
Old 06-06-2008, 07:00 PM   #4 (permalink)
Photos
I didn't see any other "how to" posts on this, but if this is redundant, please forgive.
Old 06-07-2008, 07:24 AM   #5 (permalink)
R170 Moderator and PITA
Bruce R.'s Avatar
Vehicle: 2002 SLK 32 AMG, bone stock. 1987 190E 2.3-16 valve (destroyed). 1991 300CE, a work in progress.
Attachment 181898
Attachment 181899
Not to worry, anytime you feel you want to add a DIY thread or post, just do it, they are all welcome.
Look at it this way, the data may be similar, but the wording in the post will be different, and that may help someone that may not have fully understood what the first guy may have said.
The photo's will certainly be different and can help by showing a slightly different angle and view.
You did good, thank you..... This has been added to the Tech Tips and such sticky.
"Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery."
Winston Churchill
"In my many years I have come to a conclusion that one useless man is a shame, two is a law firm and three or more is a congress."
John Adams
"If you carry a gun, people will call you paranoid. That's Ridiculous..If I have a gun, what in the hell do I have to be paranoid For."
Clint Smith, Director of Thunder Ranch
Bruce R. is offline   Reply With Quote
Old 06-07-2008, 07:43 AM   #6 (permalink)
Date registered: Sep 2006
Vehicle: 2004 CLK 240 Coupe
<snip nice DIY>
Very good post.. but I do not follow your last paragraph above. Obvously the belts must be seated correctly. But these are only driving alternators, water pumps, etc. There are no teeth involved... This is not the timing chain.
So what damage do you envisage..?
keyhole is online now   Reply With Quote
Old 06-07-2008, 01:21 PM   #7 (permalink)
Bazzle's Avatar
Date registered: Apr 2005
Vehicle: 1998 SLK230
If you use a 15mm socket you will undo the nut that holds the tensioner pulleys on. Dont do that. If it comes undone whilst holding tension on it you may loose your fingers.
Use an E10 socket on the star shaped part to lever the pulleys or an 8mm ring.
http://www.benzworld.org/forums/r170...light=fan+belt
Bazzle
Bazzle is offline   Reply With Quote
Old 06-07-2008, 01:57 PM   #8 (permalink)
Bruce R.'s Avatar
Bazzle
Good points .........
Old 06-07-2008, 05:18 PM   #9 (permalink)
If a belt starts to come apart, it can whip sections of itself around the engine compartment and break things. I actually had this happen with a Buick Roadmaster when I had the belt one tooth off. It ended up snagging and tearing up some wires - not a big deal that time, but you never know what could happen.
Old 06-07-2008, 08:01 PM   #10 (permalink)
OK thanks - I have realized that what you refer to as a 'tooth' is what I call a 'groove'. It makes sense now.
Oil Change - SLK230 Bazzle R170 SLK Class 59 10-12-2009 06:49 AM
Serpentine belts - when should you change it Dave R170 SLK Class 9 02-23-2006 06:43 AM
Is it hard to install drive belts S/c belts? Mark600RRBryant R170 SLK Class 1 09-12-2005 04:26 PM
Anyone know of muffler change (if any) from 99 to 00 SLK230?? Rohf (Seattle) R170 SLK Class 2 01-26-2002 10:09 PM
Anyone know where I can get colored seat belts? Like the custom porsche belts? Long R170 SLK Class 1 04-29-2001 04:24 PM
