Fuel Injector Cleaner (gas additive)? - Benzworld.org - Mercedes-Benz Discussion Forum
» Auto Insurance
» Featured Product
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Roadster Forums > R170 SLK Class
Old 03-29-2008, 05:00 AM   #1 (permalink)
TheJimbo's Avatar
Date registered: Mar 2006
Vehicle: 2008 ML350; 2001 SLK230 (traded in)
Anyone use these regularly? If so, which do you prefer? I've read that MB recommends using gas containing additives (Chevron) but not to use extra additives that you put in the tank yourself.
I've used STP (black bottle) in my truck for years with no problems, and in other cars too. I haven't added anything to the MB other than gas. Just wondering what you guys think about additives.
"The only thing necessary for the triumph of evil is for good men to do nothing."
TheJimbo is offline   Reply With Quote
Old 03-29-2008, 06:06 AM   #2 (permalink)
rpiotro's Avatar
Date registered: Sep 2007
Vehicle: 2012 SLK350
Top Tier Gasoline
I'll add a 12oz. bottle of Techron about every 2,000 miles for good measure.
rpiotro is offline   Reply With Quote
Old 03-29-2008, 06:47 AM   #3 (permalink)
Date registered: Oct 2007
Vehicle: 2002 SLK 230 1986 560SL 2008 Honda CRV
I've been using STP injector cleaner in the benz for a few years now with no problems.
livefreeordie is offline   Reply With Quote
Old 03-29-2008, 08:08 PM   #4 (permalink)
Vehicle: 2002 SLK32 Silver Renntech pullies
Lucas fuel treatment made my engine sound very smooth.
Jerry
jerryxu is offline   Reply With Quote
Old 03-29-2008, 08:56 PM   #5 (permalink)
Musikmann's Avatar
Vehicle: 2001 E320 - Brilliant Silver/Ash: 99,000+
+1 for Chevron's Techron. I add the large bottle to a full tank (treats up to 20 gallons) every 3000 miles as they recommend. I also use Chevron fuel exclusively.
Old 03-29-2008, 10:38 PM   #6 (permalink)
Subby_'s Avatar
Date registered: Jan 2007
Vehicle: 1998 SLK 230
i've used Redline S1 Fuel System cleaner (once in a while).
but for a good clean, these cleaners wont cut it. you either need to use "Seafoam" or Subaru Upper engine cleaner (effectivly the same ingredients as Seafoam). (search "Seafoam" on youtube to see it in action).
warm engine to opperating temp. switch off. spray half a can into the plenum/intake mainfold via a vacuum hose. wait 10min, start car keep the revs up so it wont stall and spray the other half in. wait another 10min.
start the car and rev it a bit to clear up the smoke. note that a LOT of smoke will be produced when i started mine 2-3 good black puffs of soot came out then a fair bit of thick white smoke as the cleaner was being burned up.
makes a difference? yes especialy with idle. you can bearly tell the car is on. while doing this note a few codes maybe thrown....... i got p0300 & p0304 (cylinder missfire codes) which is fine.... reset them and away you go.
Subby_ is offline   Reply With Quote
Old 03-29-2008, 11:00 PM   #7 (permalink)
Date registered: Sep 2005
I use Regane by Gumout every 5K.
Works well.
2001 SLK 320
San Francisco CA
MLTHREEFIFTY is offline   Reply With Quote
Old 03-29-2008, 11:57 PM   #8 (permalink)
SLacKer-320's Avatar
Vehicle: '01 SLK-320
I haven't used seafoam on the SLK but I have used it on my other cars. It's amazing stuff but holy hell does it ever smoke. You have no idea. And it doesn't stop either. It smokes for like 10 minutes at idle. It's fun. And the car runs great afterwards, at least in my experience.
'01 SLK-320 - Black & tan. Bone stock.
SLacKer-320 is offline   Reply With Quote
Old 03-30-2008, 04:30 AM   #9 (permalink)
TheJimbo's Avatar
Excellent feedback, thanks guys.
Interesting link on Top Tier gas retailers. Of course the two I use the most - Sunoco and Hess, are not on the list. Just my luck. Will have to find Chevron and the other Top Tier.
Old 03-31-2008, 03:47 PM   #10 (permalink)
jbrown1843's Avatar
Vehicle: 1999 SLK, and 2010 E-350
I use Lucas fuel treatment and redline products in the SLK, my Nissan Truck and the Harley. Seems like the Lucas works a bit better and Wal-mart has it most of the time.
jbrown1843 is offline   Reply With Quote
Bookmarks
Fuel Additives - Fuel Injection System Cleaner SHOOTER15 R129 SL Class 24 07-05-2009 07:57 PM
Fuel Injector Cleaner.... 2000MBML320 W163 M-Class 26 03-27-2007 06:02 AM
fuel injector cleaner? Jason Lap W126 S,SE,SEC,SEL,SD,SDL Class 11 12-03-2006 01:05 PM
fuel injector cleaner fzakaria W163 M-Class 5 03-04-2005 06:22 PM
Fuel Injector cleaner? Should this.. Ben Kokes R170 SLK Class 2 05-28-2002 10:31 AM
