Alternator regulator replacement - SLK230 - Mercedes-Benz Forum
post #1 of 14 (permalink) Old 03-22-2008, 09:58 PM Thread Starter
Bazzle's Avatar
Date registered: Apr 2005
Vehicle: Golf R32 / Prev R170 SLK
I checked my charge voltage last week, only max of 13.8v no load dropping to 13.0v with lights and heater fan on full.
Decided to try a new regulator. Mercedes Benz Parts, Mercedes Parts, Accessories
Remove NEG batt lead.
Drive front up onto ramps, chock rear wheels.
Undo 4 x 10mm sump shield screws (had to swap mine for cross head self tappers as the old ones were buggered)
Slide out lower cover.(sump shield)
(Note: If removing alt slacken off belt anr lift off crank pulley, undo 2 wire terminal nuts off alt and the 2 17mm thru bolts and lever alt down.)
To replace regulator in situ follow these inst:
Undo 3 small screws on rear dust cover.
Hold out clips on cover and remove.
Undo 2 cross head screws on Regulator and remove.
Lift out reg.
Mine had worn brushes BUT they were still making contact with a few millimetres of pressure.
Wipe slip rings and contact strip with a rag sparingly sprayed with carb cleaner etc.
Dont worry re wear on slip rings as new brushes will bed in.
If slip rings worh thru you will need a new alt anyway.
Replace reg with the new one.
Note: when ordering Reg quote the Bosch number on the alt as there are 2 types on these, 14mm and 24mm slip ring diameter, mine is 14mm. Both are 14volt.
Replace 2 screws on reg.
Clip on end cover.
Replace 3 small screws.
If you did not remove Alt connect up Neg batt term and start engine. Check voltage. Should be around 14 volts.
Mine was 14.2 with acc on
If you removed Alt, replace 2 thru bolts and 2 wires, refit drive belt and neg term.
Refit sump cover.
bazzle
Name:	P1010014 (Large).jpg
ID:	169025   Click image for larger version
Name:	P1010018 (Large).jpg
ID:	169026   Click image for larger version
Name:	P1010016 (Large).jpg
ID:	169027   Click image for larger version
Name:	P1010019 (Large).jpg
ID:	169028   Click image for larger version
Name:	P1010021 (Large).jpg
Bazzle is offline
post #2 of 14 (permalink) Old 03-22-2008, 10:02 PM Thread Starter
Bazzle's Avatar
Bazzle is offline
post #3 of 14 (permalink) Old 03-23-2008, 12:12 AM
berk's Avatar
Date registered: Oct 2005
Vehicle: 99 slk230 sport
were you having charge problems? it would seem 13.8 would be sufficient to keep it charged well. 13 is a bit low though.
berk is offline
post #4 of 14 (permalink) Old 03-23-2008, 12:44 AM Thread Starter
Bazzle's Avatar
Many, Many tears (years) ago when I started my Electrical and mechanical engineering degree we were taught the preventive maintenance principles.
Now a days its dont touch unless it broke...
It has served me well over the years. If I see something that is close to its limits I will have a look. For $26 this one was well worth the look
Bazzle
Bazzle is offline
post #5 of 14 (permalink) Old 03-29-2008, 06:48 PM
tobyls2555's Avatar
Date registered: Sep 2006
Vehicle: Mercedes Benz Slk230 1999, Mercedes Benz C240 2001
Bazzle>> I emailed and asked the price today and I was told the Voltage regulator was $49, shipping was $24. You mentioned you got it last week for $26. Any idea?
Thank You
Jocelyn
tobyls2555 is offline
post #6 of 14 (permalink) Old 03-29-2008, 07:40 PM Thread Starter
Bazzle's Avatar
Thank You
Jocelyn
Emailed whom?
Where do you live on the planet?
Heres one link:
http://cgi.ebay.com/ebaymotors/ws/eB...019573390&rd=1
You need to know what alternator is in yours??
Bazzle
Bazzle is offline
post #7 of 14 (permalink) Old 03-30-2008, 06:27 PM
tobyls2555's Avatar
bazzle
I emailed the people from your link and I was told it is called a voltage regulator, $49, shipping was $24.My car is a 1999 SLK 230. I was wondering if anyone can tell where I might find my alternator so I can locate its number.
Thank You
Jocelyn
post #8 of 14 (permalink) Old 03-30-2008, 09:54 PM Thread Starter
Bazzle's Avatar
If you see my 2nd last pic that one shows the part number on Alt.
You will have to drop the lower engine cover as per my instructions above. Its on the bottom right hand side of engine front.
Bazzle
Bazzle is offline
post #9 of 14 (permalink) Old 03-31-2008, 10:13 AM
tobyls2555's Avatar
Thank You Bazzle!
post #10 of 14 (permalink) Old 03-31-2008, 10:55 AM
Arotished's Avatar
Date registered: Jun 2007
Vehicle: 1999 MB SLK 230
Mine is 14.18 unload and 14.01 load (all the light's on and airblower) guess that i dont need to change mine jet.
1999 230 SLK
Arotished is offline
Alternator or Voltage Regulator? Gregs300CD W123 E,CE,D,CD,TD,TE Class 17 09-18-2015 08:45 AM
Alternator Voltage regulator Merc600sec W140 S-Class 14 12-12-2011 12:30 PM
Alternator and/or voltage regulator? rharling W210 E50 AMG, E55 AMG 1 09-02-2007 12:13 PM
Alternator, regulator issue barry_s_u W126 S,SE,SEC,SEL,SD,SDL Class 2 02-06-2006 01:10 AM
alternator and voltage regulator HELP! saporter W201 190-Class 5 03-28-2005 11:18 PM
