» Site Navigation
» Other Sites
Old 03-05-2008, 12:29 PM   #11 (permalink)
R170 Moderator and PITA
Bruce R.'s Avatar
Vehicle: 2002 SLK 32 AMG, bone stock. 1987 190E 2.3-16 Valve, NOT bone stock...
Originally Posted by anton_slk View Post
Bruce,
The vacuum hose I referring to is not a black wire loom but a small yellow-ish hose behind it. On the picture it is missing a whole section.
You can also see a part of this hose on the first picture just above the wire loom.
I see it now, sorry, the words "section missing" didn't register for some reason...
Bazzle and cacecef seem to have the answer covered pretty well.
2002 SLK 32,
1987 190E 2.3-16 valve
"A vote is like a rifle: its usefulness depends upon the character of the user."
Theodore Roosevelt
"If you love wealth greater than liberty, the tranquility of servitude greater than the animating contest of freedom, go home and leave us in peace. We seek not your council, nor your arms".
Samuel Adams
"In any survival situation, you should try to keep your friends alive as long as possible. They stay fresh longer that way.
Unknown
Bruce R. is offline   Reply With Quote
Old 03-05-2008, 09:26 PM   #12 (permalink)
Date registered: Jun 2006
Vehicle: '98 slk 230
Smile
Bazzle, cacecef, Bruce R.,
Thanks a lot for advice!
Drove today to the dealership and picked up a plastic hose ($6 per meter, they gave it to me for free). 5 minutes to replace the hose - simply cut it to the right length and plug it into the rubber connectors on both ends. The old hose got very brittle and was breaking easily. Will see tomorrow if the codes get cleared.
While taking off the cover saw a lot of oil build-up on a Camshaft Adjuster Magnet. Cleaned it to check if new oil appears.
anton_slk is offline   Reply With Quote
Old 03-06-2008, 04:35 AM   #13 (permalink)
Bruce R.'s Avatar
It's interesting to see or hear of a dealer that takes care of their customers; they are not ALL thieves and hustlers. It's good to hear something nice about them once in a while....
Old 03-18-2008, 11:59 AM   #14 (permalink)
cocktailsfirst's Avatar
Date registered: Sep 2005
Vehicle: 1999 SLK230
Send a message via Yahoo to cocktailsfirst
It was the same line broken that caused my errors. I repaired the broken vacuum line with a repair part from my local auto parts store and that resolved my issue. Cost less than $1 USD.
1999 SLK230
Santa Barbara, CA
cocktailsfirst is offline   Reply With Quote
Old 05-14-2008, 12:37 PM   #15 (permalink)
Date registered: Jun 2005
Vehicle: '98 SLK 230
Turns out, I got the very same scenario. Happened right after an oil change - had codes P0410 and P0105. Replaced the air check valve (which was all rusted out). Cleared the codes, got them back. Just today, got the P1519 code to boot, and I checked that very area, and it's split (but no section is missing). I'll go see if I can fix it with tubing or new hose.
DO_Doc is offline   Reply With Quote
Old 05-14-2008, 12:48 PM   #16 (permalink)
I'm pretty sure that fixing a crack in the vacuum tube will fix it. Worked for me and for the other forum member (cocktailsfirst).
The easiest fix is to replace the whole section of the tube, which you can get from the dealer for almost nothing. It simply plugs into rubber sockets on both ends.
Old 05-17-2008, 04:40 PM   #17 (permalink)
All codes resolved. Replaced the line with air line from Autozone. Took five minutes.
How to check code for check engine light 94 E320 W124 Synd W124 E,CE,D,TD Class 1 05-24-2007 02:37 PM
6k miles and check engine/oil light didn't go on yet... jackie100 General Mercedes-Benz 26 03-09-2007 09:09 AM
Check engine electronics, Check oil level.+ others bondale W210 E-Class 5 11-10-2006 12:02 AM
check engine light - octane change? mikewired W163 M-Class 7 05-13-2006 09:32 PM
Check Engine light on after oil change Guest (MBNZ) W124 E,CE,D,TD Class 1 05-29-2002 05:33 PM
