Coolant level sensor - Mercedes-Benz Forum
post #1 of 13 (permalink) Old 02-25-2008, 08:12 AM Thread Starter
Date registered: Oct 2005
Vehicle: 1997 SLK 230K
Question Coolant level sensor
Hi, I just changed the thermostat and while driving the coolant level light came on yesterday. Checked, correct, the coolant dropped a little during the repair, but I then topped the coolant and the light is still on ??
how does the coolant level sensor work? I searched the forums but only found some answers on bmw forums which may not apply to mercs I think.
leventguner is offline
post #2 of 13 (permalink) Old 02-25-2008, 08:45 AM
Bruce R.'s Avatar
Vehicle: 2002 SLK 32 AMG, bone stock. 1987 190E 2.3-16 valve (destroyed). 2005 E320 new toy.
Quoted: 41 Post(s)
Check the water level in you windshield washer tank as well. For some reason "they" decided that both tanks should go through the same warning system...
"Negotiating with Obama is like playing chess with a pigeon, the pigeon knocks over all the pieces, on the board and then struts around like it won the game."
Vladimir Putin
"They have gun control in Cuba. They have universal health care in Cuba. So why do they want to come here?"
Paul Harvey 8/31/94
"The only people who have quick answers don't have the responsibility of making the decisions."
Justice Clarence Thomas
Bruce R. is offline
post #3 of 13 (permalink) Old 02-25-2008, 09:57 AM Thread Starter
I filled that up too, no change.. since it fired because of low coolant and stayed on after it seems unlikely to me that the sensor failed.. but I cant be sure..
post #4 of 13 (permalink) Old 02-25-2008, 10:23 AM
Bruce R.'s Avatar
Quoted: 41 Post(s)
OK, the radiator tank is full, the washer tank is full, and the float in the fill neck is free to move, right?
The next likely thing is the sensor itself.
Vladimir Putin
Paul Harvey 8/31/94
Bruce R. is offline
post #5 of 13 (permalink) Old 02-25-2008, 10:57 AM Thread Starter
the float, I am not sure about that, I noticed a plus sign while filling but I don't see it always.. how does the float and the sensor work together?
post #6 of 13 (permalink) Old 02-25-2008, 11:29 AM Thread Starter
Lightbulb
ok, I searched the posts about the float, I will try to pull it up with a screwdriver to see if it moves freely inside.
post #7 of 13 (permalink) Old 02-25-2008, 06:09 PM
DickB's Avatar
Date registered: Dec 2002
Vehicle: 1999 SLK 230
Not the case on my '99. There are separate indicators for each. It is true that the two sensors are wired in series, but they also each have separate series/parallel resistors in them, so that the instrument cluster electronics can tell which sensor is triggered. In the diagram, S41 turns on E11 (coolant) and S42 turns on E13 (washer).
ID:	164628   Click image for larger version
DickB is offline
post #8 of 13 (permalink) Old 02-26-2008, 01:46 AM Thread Starter
Smile
Thanks to both of you, I pulled the float a little bit and now the light is off. It is just under the surface of the fluid and I assume it is ok.
post #9 of 13 (permalink) Old 02-26-2008, 06:16 AM
Bruce R.'s Avatar
Quoted: 41 Post(s)
OK, I'm sure you are correct, the '32 may be slightly different, and things have obviously changed.
My radiator fill light came on for no apparent reason with the tank "full" and the washer tank low. I added fluid to the washer tank as has been described in some other posts that I recalled and the light has not come on again.... The washer needed almost a gallon of fluid to bring it up to full... !
Thanks for the schematic, it helps a lot.
Vladimir Putin
Paul Harvey 8/31/94
Bruce R. is offline
post #10 of 13 (permalink) Old 02-26-2008, 10:52 AM
On my 99 SLK230, I had the same problem. After the dealer replaced the coolant level sensor two or three times under warranty, they filled the windshield washer tank and the problem disappeared. So, maybe some cars are different or maybe things changed since my car was built but that was my experience.
pfphipps is offline
1993 600SEL coolant level sensor, where is it?? foxmuldor W140 S-Class 4 12-29-2010 02:39 AM
Coolant Level Sensor 01E320 Benzo DJ W210 E-Class 3 09-29-2008 01:51 PM
Coolant Level COmes on Creative85 W210 E-Class 0 12-04-2006 06:59 PM
Coolant level sensor warning YellowSLK230 R170 SLK-Class 9 11-03-2004 05:37 AM
Coolant Level anant369 R170 SLK-Class 2 01-14-2003 01:23 PM
