Old 02-24-2008, 07:38 PM   #1 (permalink)
bowser881's Avatar
Vehicle: 03' SLK 230
Check Engine Light Help (have codes)
Check Engine light has been on for about 6months I have been driving it and there are no preformance issues and it has been running fine. However inspection is due this month and it wont pass because of this. I pulled the codes and these are what came up.... P0131 P0171 P0130 P0132 and P0135 any idea what these mean or why it would have came on? Help would def. be appriciated. Thanks!!
bowser881 is offline   Reply With Quote
Old 02-24-2008, 09:36 PM   #2 (permalink)
Date registered: Oct 2006
P0131=Oxygen O2 Sensor Circuit Low Voltage (Bank 1, Sensor 1)
P0171=System Too Lean (Bank 1)
P0130=O2 Sensor Circuit Malfunction (Bank 1 Sensor 1)
P0132=O2 Oxygen Sensor Circuit High Voltage (Bank1, Sensor1)
P0135=Oxygen O2 Sensor Heater Circuit Malfunction (Bank 1, Sensor 1)
My guess is the oxygen sensor is bad. The easiest thing to try first would be to replace the oxygen sensor on Bank 1 (whichever one that is). After that, disconnect the battery to reset the OBD (or use the OBD code reader). Just remember that the OBD will fail even with the light off if you reset it immediately before the test. Good luck!
FartMan is offline   Reply With Quote
Old 02-24-2008, 09:49 PM   #3 (permalink)
bowser881's Avatar
I hope thats all it is 02 sensor isnt bad at all... I was worried it would be something major with that many codes. I will have the 02 sensor replaced this week hopfully that will take care of it. Thanks for the help and putting my mind at ease... =)
Old 02-25-2008, 05:54 PM   #4 (permalink)
You're welcome. The OBD system is really a good solution to emissions restrictions. The computer monitors the function of all of the components of the emission control system. If there is a malfunction in any component, the "check engine" or Malfunction Indicator Light (MIL) lights. It would be nice if there was a readout that let you know why the MIL lit up but I suppose most people wouldn't know what to do about it anyway. The system really should be serviced by a trained and qualified techinician. Most times, it is a pretty simple problem.
My cousin has a Toyota and she called me one day when her MIL came on. I hooked up my scannner and pulled the code. It turned out that the code that set the MIL related to the evaporative emissions control system. The fix was tightening the gas cap and resetting the OBD!
In your case, you probably just have a bad oxygen sensor. They fail pretty regularly. I doubt that there is anything more wrong with it than that. The law of Occam's razor applies here. The most likely answer is probably the simplest.
Good luck. Let us know how it works out.
Old 02-29-2008, 08:27 AM   #5 (permalink)
bowser881's Avatar
O2 Sensor fixed the check engine light and I am now inspected... I also needed front ball joints but I have a hook up at a AUDI dealership they did everything for under $600.... Is it normal for the ball joints to need replaced at around 50k?
Old 02-29-2008, 08:59 AM   #6 (permalink)
BenzWorld W203 Host
Buellwinkle's Avatar
Vehicle: C230K Sport Sedan
It would seem odd to me that at 50K miles you need ball joints when ours has twice that many miles and doesn't. On the otherhand, you drive in the northeast were the roads may not be as smooth as So Cal freeways. Ball joints are not good to mess with, if it truly needs them, get them replaced because the wheel can colapse and even fall off. You can check by trying to move the top of the tire in and out by hand and see if there's play, there shouldn't be any.
Old 02-29-2008, 09:28 AM   #7 (permalink)
bowser881's Avatar
I had them replaced... needed them for inspection...
Old 02-29-2008, 01:02 PM   #8 (permalink)
Kirill's Avatar
Date registered: Jul 2003
Vehicle: 01 SLK 320 MT6
You should come visit Chicago - our roads looks like they were bombed.
Kirill
Kirill is offline   Reply With Quote
Old 02-29-2008, 01:08 PM   #9 (permalink)
Bazzle's Avatar
Date registered: Apr 2005
Vehicle: 1998 SLK230
Through the MB models that use the same ball joints some seem to last ages, others about 50,000k
Bazz
Bazzle is offline   Reply With Quote
5 different codes for recent Check Engine Light prtdvl R170 SLK Class 0 02-19-2008 06:24 PM
Check Engine Light is on - How do I get the codes? jtoma878 W208 CLK Class 2 08-29-2007 08:58 AM
Check engine light on 97 E420, codes help? cabby850 W210 E-Class 0 12-05-2006 03:39 PM
Check engine light, codes 8 and 26 hsv5000 W124 E,CE,D,TD Class 2 05-01-2004 12:57 AM
O2 sensor and check engine light codes... ewalberg G-Class 3 04-21-2004 01:09 PM
