Old 02-14-2008, 11:08 PM   #1 (permalink)
ALephart's Avatar
Date registered: Dec 2006
Vehicle: 1998 SLK 230 KOMPRESSOR
Send a message via AIM to ALephart
Any tips to removing headliner?
I have a couple pieces of sound suppression mat left over. So I thought about covering the roof. I removed the 3 screw from the front of the headliner. Does everything else just snap apart?
All the best,
Aaron Lephart
smart car info www.smartcar451.com
SLK32 Front/rear calipers and rotors
Hawk EP + pads
ATE fluid
Stoptech lines
AMG 17'' sport rims with Toyo T1R's
ASP 10% overdrive pulley, Bosch FR5DC plugs, fuel pressure riser
LED interior lights.
KONI adjustable shocks
Ceramic coated exhaust manifold and valvecover.
NEW OEM black interior
Simpleroof
ScanguageII
Projector beam headlamps
4500K Xenon/HID headlight bulbs
Sprintbooster
CLK style grill
OEM SL antenna color matched
Dynamat
ALephart is offline   Reply With Quote
Old 02-15-2008, 06:23 AM   #2 (permalink)
430
Date registered: Oct 2002
Vehicle: SLK32, ML430
There was a thread about a leaking roof which contained information on removing the roof liner.
430 is offline   Reply With Quote
Old 02-15-2008, 12:15 PM   #3 (permalink)
ALephart's Avatar
Ugg, I totally missed the 2 bottom screws on the plastic rail, so I just broke them to get them off before I realized that, $17.00 each from MB, they where scratched anyhow.
Aaron Lephart
headliner help wv240d W123 E,CE,D,CD,TD,TE Class 2 04-14-2006 07:49 PM
need help removing the headliner Bisaya W163 M-Class 16 10-28-2005 07:39 AM
280ge removing engine without removing auto trans toka G-Class 8 09-17-2003 05:56 AM
Ok, my rusted tips is gone Neww SS tips installled JimB W163 M-Class 18 05-04-2003 08:16 PM
Any tips for removing scratches & fine lines? Christian R170 SLK Class 3 03-28-2002 04:20 PM
