» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Roadster Forums > R170 SLK Class
Old 01-28-2008, 03:05 PM   #1 (permalink)
Steve Johnson's Avatar
Date registered: Nov 2004
Vehicle: 2003 SLK230
M62 pulley size?
For those 98-99 230's I need the size of the blower pulley. I know Snogard runs the 80mm Brabus blower pulley and I need to know the size of the OEM pulley. M45 is 2.75 and can only run a 2.65 and that is only after blower snout is turned down! 4% power increase from running the smaller pulley on the M45!
2003 SLK230 Auto transmission
Steve Johnson is offline   Reply With Quote
Old 01-28-2008, 09:38 PM   #2 (permalink)
Date registered: Mar 2007
Vehicle: SLK 230K BRABUS now, Mercedes 190E 2,3 16V,SMART BRABUS,BMW E39 M5,E31 850i,E32 750i,etc (all ex)
Steve, 80mm written in my signature is my typing mistake. In fact my BRABUS K1 wheel have diameter arround 91 mm, and diameter of OEM stock pulley is 100mm at the belt line. If you want, i can measure EXACTLY diameter od OEM pulley and K1 pulley, as i have both of them at home.
BRABUS:
-susp.
-18"MonoblockIV
-body
-hand brake
-roll bars
-K1S kit
-IC
-exhaust
FT crank pulley 225mm
double RAM-CAI
K&N
Custom intake ALU(SC to IC & IC to TB)pipeing
New M62(0,7bar/2000rpm&1,05bar/5500rpm)
Ported SC outlet&inlet
Elim.MAF&TB screen
4BAR FPR
SS headers(thermotec wraped)
Servo pump&Alternator UD pulleys
C55AMG Fr.brakes(Brembo345mm/4piston)
SLK55AMG Re.brakes(Brembo330mm/4piston)
SS brake lines
17mm spacers 4x
Wiechers chassy reinforcement
Snogard is offline   Reply With Quote
Old 01-28-2008, 11:50 PM   #3 (permalink)
Arotished's Avatar
Date registered: Jun 2007
Vehicle: 1999 MB SLK 230
If you only had two^^
1999 230 SLK
Arotished is offline   Reply With Quote
Old 01-29-2008, 01:25 AM   #4 (permalink)
I will do what ever i can to get you one K1 wheel (for reasonable price of course). That is a promise my friend!
Eaton m62 specification Arotished R170 SLK Class 12 02-22-2008 06:42 AM
New/overhaul Eaton m62 Arotished R170 SLK Class 11 02-22-2008 06:36 AM
2002 c32 crank pulley size? 12seccivy W203 C32 AMG, C55 AMG 8 10-03-2007 07:35 PM
56" ASP pulley belt size or part no ZX7/9RR W203 C-Class 1 03-11-2007 02:45 PM
Eaton M62 supercharger available martinstimson R171 SLK Class 0 02-06-2003 07:12 AM
