» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Roadster Forums > R170 SLK Class
Old 02-21-2008, 07:14 AM   #11 (permalink)
Date registered: Mar 2007
Vehicle: SLK 230K BRABUS now, Mercedes 190E 2,3 16V,SMART BRABUS,BMW E39 M5,E31 850i,E32 750i,etc (all ex)
[quote=Snogard;2753863]
Originally Posted by furlined View Post
Snogard, I never said a m90 should be substituted for the m62, I just asked if the higher output would make a significant gain. The eaton Third Generation m90 is zero longer than the m62. Before you attack me check your facts. I am not seeking to invalidate your posts, so ease up. we are all here to have fun and make improvements.
You didnt ask for opinion, you said that you have hard time to believe me that M90 will bring no gain. Let me citate your words: "But I find it hard to believe you wouldn't see any gains compared to the lower output M62 driven equally" End of citat.
And that statement is different then question. So do not turn your words when you see that you loose arguments.
M90 is (in terms of free space under 230k hood) A LOT bigger than M62. And until wright NOW you never before mention that you have in mind 3rd (and not 2nd) generation of M90, so before YOU attack ME, do your own homework and next time write down specificaly that you dont have in mind 2nd generation of M90 like we all others think (which is from the time of M62 which is in the M111).
Btw. i own a car with M90 so beleave me i know a lenghth of each generation of M90.
BRABUS:
-susp.
-18"MonoblockIV
-body
-hand brake
-roll bars
-K1S kit
-IC
-exhaust
FT crank pulley 225mm
double RAM-CAI
K&N
Custom intake ALU(SC to IC & IC to TB)pipeing
New M62(0,7bar/2000rpm&1,05bar/5500rpm)
Ported SC outlet&inlet
Elim.MAF&TB screen
4BAR FPR
SS headers(thermotec wraped)
Servo pump&Alternator UD pulleys
C55AMG Fr.brakes(Brembo345mm/4piston)
SLK55AMG Re.brakes(Brembo330mm/4piston)
SS brake lines
17mm spacers 4x
Wiechers chassy reinforcement
Snogard is offline   Reply With Quote
Old 02-21-2008, 01:41 PM   #12 (permalink)
furlined's Avatar
Date registered: Feb 2008
Vehicle: 1998 SLK230
Thanks for clearing up the confusion I created by not specifying a third generation my bad. Now that we are on the same page I appreciate the knowledge that dual pulley's make a better upgrade than the compressor swap. (I still want to believe the M90 gen 3 would make a big difference. has anyone researched that?) My goal is to create 275-300 HP from this engine. It sounds as if you have come close to those figures with mostly external mods congratulations, I have learned a lot in a short time on this forum
BTW I own a car with a GMC671 roots type blower and would never try to put in in a m111. That might be cute on the slk with a snorkel hood scoop!
furlined is offline   Reply With Quote
Old 02-22-2008, 06:42 AM   #13 (permalink)
Furlined, i see that you are good man! If you ever need any info or advice, i am here for you!
P.S. Glad that we have another member with the same pation and goals!!!
New/overhaul Eaton m62 Arotished R170 SLK Class 11 02-22-2008 06:36 AM
Eaton M62 Part number Prober PGT General Mercedes-Benz 1 11-25-2006 08:16 PM
Eaton M62 blower questions redhotjbody W203 C-Class 2 10-05-2004 01:02 PM
Eaton M62 supecharger available EXCELLENT martinstimson General Mercedes-Benz 0 02-06-2003 07:13 AM
Eaton M62 supercharger available martinstimson R171 SLK Class 0 02-06-2003 07:12 AM
