» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Roadster Forums > R170 SLK Class
Old 01-17-2008, 05:40 AM   #1 (permalink)
Arotished's Avatar
Date registered: Jun 2007
Vehicle: 1999 MB SLK 230
New/overhaul Eaton m62
I'm looking for a new or a overhaul eaton m62 komressor for my engine. Since I'm gonna install a new kompressorwheel on it(allrwady have a larger crank wheel), I want a SC in good condition. I have searce alittle but I cant find a company that does it. All I can find is used one on ebay. So, is there some that overhaul the eaton m62?
1999 230 SLK
Arotished is offline   Reply With Quote
Old 01-17-2008, 08:18 AM   #2 (permalink)
Arotished's Avatar
I have found Magnuson Products and C.A.P.A, others?
I dont know if the sell/overhaul SC, I'm waithing of a answer
from them.
Old 01-17-2008, 10:15 AM   #3 (permalink)
Steve Johnson's Avatar
Date registered: Nov 2004
Vehicle: 2003 SLK230
You need to talk to Wade Embree from thehighspeedlab.com. Not only can he make a smaller blower pulley he can also strip and recoat your inner casing/rotors with an abrabdable coating that will vitrually eliminate the rather larger gaps on older blower like the M62 and the M45!
2003 SLK230 Auto transmission
Steve Johnson is offline   Reply With Quote
Old 01-17-2008, 05:51 PM   #4 (permalink)
Arotished's Avatar
THANKS STEVE
Old 01-17-2008, 07:13 PM   #5 (permalink)
DickB's Avatar
Date registered: Dec 2002
Vehicle: 1999 SLK 230
from them.
I had an aftermarket Eaton supercharger on my Miata. It's been a while, but Magnuson was used by several Miata owners for repair and overhaul. I contacted them for repair information via email, and they were very helpful.
DickB is offline   Reply With Quote
Old 01-17-2008, 09:42 PM   #6 (permalink)
Magnusson and Capa are the authorized dealers and repair/rbnbuild dist. for Eaton but if a person is going to take the time to have the blower rebuilt then making it more efficent while installing a smaller pulley to spin it even faster is the only way to proceed IMHO!
Old 01-19-2008, 12:08 AM   #7 (permalink)
Arotished's Avatar
I got an answer now, 550 for a total M62 overhaul pluss coating of the rotor, did'nt say anything about the coating of the case. Anyway, then I'll just have to remove the SC. Is it just to take of the Intakehouse and a couple of hoses to remove it?
Old 02-20-2008, 10:10 PM   #8 (permalink)
furlined's Avatar
Date registered: Feb 2008
Vehicle: 1998 SLK230
I know that the pully mod in an inexpensive way to increase boost, but if boost is the trick why not retrofit the m90 eaton supercharger to the slk230
furlined is offline   Reply With Quote
Old 02-20-2008, 11:33 PM   #9 (permalink)
~BANNED~
linh's Avatar
Vehicle: 06' CLK 500 Cabrio, 01' CL 55, 01' CLK 430, 04' Civic
Kleemann went throught with R&D but scraped it in the end. Seriously guys, I know it fun modding but if power is what you want, a used Slk 32 is your best option. Mods like header, exhaust, cams, throttle body....etc give you pennies hp and cost alot of money.
linh is offline   Reply With Quote
Old 02-21-2008, 06:13 AM   #10 (permalink)
Date registered: Mar 2007
Vehicle: SLK 230K BRABUS now, Mercedes 190E 2,3 16V,SMART BRABUS,BMW E39 M5,E31 850i,E32 750i,etc (all ex)
I give you wright about that statement, but you should know even better then me that its not the same if you have stock car who anyone can buy if he have money, or if you have a car which is masterpiece for you, a car you work on for hours , days, months, even years to mod him to that level. And that feeling of owning such a car could not be beatten by owning no other stock car.
But, if you are going just for power, then of course-it is cheaper and much easyer to take SLIK 32 write at the beggining.
BRABUS:
-susp.
-18"MonoblockIV
-body
-hand brake
-roll bars
-K1S kit
-IC
-exhaust
FT crank pulley 225mm
double RAM-CAI
K&N
Custom intake ALU(SC to IC & IC to TB)pipeing
New M62(0,7bar/2000rpm&1,05bar/5500rpm)
Ported SC outlet&inlet
Elim.MAF&TB screen
4BAR FPR
SS headers(thermotec wraped)
Servo pump&Alternator UD pulleys
C55AMG Fr.brakes(Brembo345mm/4piston)
SLK55AMG Re.brakes(Brembo330mm/4piston)
SS brake lines
17mm spacers 4x
Wiechers chassy reinforcement
Snogard is offline   Reply With Quote
Eaton M62 Part number Prober PGT General Mercedes-Benz 1 11-25-2006 08:16 PM
Eaton M62 blower questions redhotjbody W203 C-Class 2 10-05-2004 01:02 PM
Eaton/Mercedes M62 supercharger available martinstimson W208 CLK Class 7 02-08-2003 06:52 AM
Eaton M62 supecharger available EXCELLENT martinstimson General Mercedes-Benz 0 02-06-2003 07:13 AM
Eaton M62 supercharger available martinstimson R171 SLK Class 0 02-06-2003 07:12 AM
