Old 12-05-2007, 02:26 AM   #1 (permalink)
Date registered: Jul 2007
Help me!! oil leakage
my magnetic clutch has a problem
as picture shown, there are two oil leakage spots
In A site(connector), that problem is so famous in korea
leakage oil soak into cable and mass up electronic equipment(such as ECU)
In B site, There is no gasket between magnetic clutch and engine block.
If I replace clutch into new one, I wouldn't fix it up I guess..
Help me!!
Is there anyone who have the same problem like mine
nfoo is offline   Reply With Quote
Old 12-05-2007, 02:34 AM   #2 (permalink)
livefreeordie's Avatar
Date registered: Oct 2007
Vehicle: 02 SLK230 Komp. 08 Honda CRV
Welcome to the forum.
You need to give us more details about your leak.
What year and model do you have???
livefreeordie is offline   Reply With Quote
Old 12-05-2007, 03:38 AM   #3 (permalink)
Vehicle: 1997 SLK230 K & 1978 280CE
Seems to be quite a common problem here in Australia also......
Potential for very expensive damage to ECU that can be a nightmare to diagnose and fix........
Clutch shouldn't need replacing....just the Cam Adj. Magnet.....should fix both leaks if installed correctly
MB has a special sealant...expensive... part #002-989-00-20.... alternatives can be used, but should not contain silicone....Hylomar has been suggested in a post by a Benz Tech......
There is also a wiring loom modification......... GEO25D Starter Line #271 150 27 33
....this has been designed to stop the tracking of any oil leak.........end connections sometimes have to be modified........
Good Luck
David
David in Australia is offline   Reply With Quote
Old 12-05-2007, 04:56 AM   #4 (permalink)
my car is slk 230(2002)
and I use a cable extension(I guess #27115027 is, I can find no pix. so I am not sure)
that prevent leakage to soak cable, but still can't stop leaking
and the most serious thing is leakage in B site. leak oil massed up my engine room.
David said "just the Cam Adj. Magnet", sorry I can't understand it.
David mean that just disassamble the magnetic clutch and assamble the magnetic properly?
or adjust other parts?
Old 12-05-2007, 06:41 AM   #5 (permalink)
Date registered: Apr 2007
Vehicle: 98 red 230 slk
Yes, Only replace gold looking round cam adjust magnet. Remove the three bolts and look at old one to see where gasket was and apply some gasket maker to new one. Use only gasket maker with no silicone in it.
cacecef is offline   Reply With Quote
Old 12-05-2007, 08:15 AM   #6 (permalink)
Bazzle's Avatar
Date registered: Apr 2005
Vehicle: 1998 SLK230
http://www.benzworld.org/forums/r170...#37;2C+Project
Common sadly.
If oil at connector replace magnet assembly (the bit held on by the 3 allen screws.
If just a weeping seal remove, clean up and as stated use a sealer there.
If any oil in loom clean thouroughly. Check other end in ECM box in rear of engine bay to ensure it has not wicked through.
Take Davids advise.
Bazzle
Bazzle is offline   Reply With Quote
C 220 has oil leakage student123 W202 C-Class 3 08-02-2007 12:41 AM
Oil Leakage Curacao W202 C-Class 6 09-19-2006 08:23 AM
1994 C280 Oil Leakage nikos8 General Mercedes-Benz 3 02-19-2006 04:07 PM
117 Head gasket oil Leakage & fumes inside car MBL87560SEC W126 S,SE,SEC,SEL,SD,SDL Class 12 12-05-2005 07:41 PM
Oil Cooler Hoses, General Oil Leakage Questions Pauls82300SD W126 S,SE,SEC,SEL,SD,SDL Class 0 06-15-2005 08:38 AM
