41 - 49 of 49 Posts
Was this valve moved for the post face lift (after 2000) models? I don't have these under my airbox, it looks like they're located between the engine and the firewall. I'm getting P0410 too, need to swap it out.
I have a 2002 and the check valve is on the other side of the engine. A recent post by livefreeordie explains how he recently changed his check valve. The pics look like the layout I have. See "Help Needed - Cold Start" thread.
2001 E320 Wagon - P0140/Carbon
First of all, I'm new to the forum. I've owned my 2001 E320 Wagon since 2002 and have over 163,000 miles on it - actually it's my wife's car. We're getting the P0140 error code and the dealer is telling us that the heads need to be removed and the carbon cleaned. I assume that they've checked all of the usual suspects to arrive at this conclusion. I'll check the valves and everything else before I commit to the recommended procedure.
I guess the head removal is a multi-day procedure. Has anyone gone this route? If so, can you provide any lessons-learned? . I'm thinking of doing the work myself but need a good manual. I've seen the Star DVD's but can't find them available anywhere. Any suggestions? What about special tools. Do I need anything that is not available at the local parts store? As for competence, I am an amateur auto restorer. I've rebuilt cars and bodies for approx 30 years - geeze has it been that long? I feel comfortable around engines but would welcome any advice - including don't do it yourself if that is the collective feeling.
Thanks
Try posting this in the W210 forum. The 320 is the common engine there and there is a lot of expertise on that forum. But to me the dealers suggestion sounds a bit extreme - maybe he wants to make some extra money? :eek:
Mine is cut to just under .25 inch. Dremel tool, hack saw and elbow grease. Wrench was under $10. When I replaced mine the old valve was rusted and flaking debris. I took a shop vac and cleaned out the downstream intake hose to the TB. It was loaded with junk. About a month later got the MAF code , which I have to assume was caused by the garbage from the check valve. I cleaned the MAF a few times and it cleared the fault. Its been 4 years with no issues.
Found a Combination Super Thin Wrench - 24mm x 27mm presently listed as:
Regular Price: $7.67
Sale Price: $5.48​
Bare url: http://www.ntxtools.com/network-tool-warehouse/V8T-812427.html
Features:
  • Specifically designed thinner than regular wrenches for use on thin nuts.
  • Made of high strength manganese alloy steel - heat treated and tempered to maximize strength.
  • Not for high torque applications.
Is the last "feature" likely to be a problem for this job?
UPS ground shipping to my address is $10.25. :(
Given the writeup at this page, it looks like the thin wrench above might not be up to the task. That same writeup, though, recommends the "Armstrong 28-034 27mm wrench." The 28-034, though is actually 1-1/16" (26.9875mm). Google finds several places selling it. Might be an option for those of us not able to take the bench grinder approach.
Update: Stanley has a similar wrench that is actually metric: Stanley Proto J3527M Metric Thin Sevice Wrench 27mm.
41 - 49 of 49 Posts
